        January 24th, 2018, 12:30 pm
			I have been using jRiver on my laptop as a player for testing and also just for music when working at home on my PC.  The other day, both jRiver and Windows Explorer suddenly refused to see my network drives.  Restarting did not bring the recalcitrant PC into submission. I could ping all the devices and the right hand side of explorer could see them and even allow me to pin them to the Quick Access section of Explorer so Windows knew they were there.  What to do?  Google to the rescue, sort of.  After about a dozen false starts from people claiming to know the solution I found the real answer.  It is outlined in the attached document.  After following the procedure, all is well again.  Aren't computers fun? NOT.
					- Attachments
			- Restore Missing Network Devices in WIndows Explorer.pdf
			- (333.54 KiB) Downloaded 907 times
        January 24th, 2018, 12:36 pm
			thanks Tom
So off to check the six other win10 systems
        January 24th, 2018, 12:43 pm
			SMB was the target of some pretty serious malware last year, so Microsoft locked it down pretty tight in response.
        January 24th, 2018, 2:03 pm
			tomp wrote:I have been using jRiver on my laptop as a player for testing and also just for music when working at home on my PC.  The other day, both jRiver and Windows Explorer suddenly refused to see my network drives.  Restarting did not bring the recalcitrant PC into submission. I could ping all the devices and the right hand side of explorer could see them and even allow me to pin them to the Quick Access section of Explorer so Windows knew they were there.  What to do?  Google to the rescue, sort of.  After about a dozen false starts from people claiming to know the solution I found the real answer.  It is outlined in the attached document.  After following the procedure, all is well again.  Aren't computers fun? NOT.
Hmmm.  I never had that problem with my turntable.
        January 24th, 2018, 2:24 pm
			Wow!
 , Wow!
 , Grumble rumble!
 , Grumble rumble!
        January 24th, 2018, 3:08 pm
			The easy road is to only to go with what you know instead of trying new things
        January 24th, 2018, 3:11 pm
			Pelliott321 wrote:The easy road is to only to go with what you know instead of trying new things
Yeah, but you don't learn anything that way
        January 24th, 2018, 3:20 pm
			If you do not continue to learn then your dead
	        Powered by phpBB © phpBB Group.
		    phpBB Mobile / SEO by Artodia.
