It is currently November 28th, 2026, 6:21 pm
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: January 6th, 2018, 3:28 pm
Both 2x12's are done and ready for driver install and wiring.
PostPosted: January 6th, 2018, 5:18 pm
Installing the drivers and wiring.
PostPosted: January 7th, 2018, 10:24 am
Drivers installed and wiring for the speakers is done. Now for some testing.
PostPosted: January 7th, 2018, 5:46 pm
The first servo sub is working and trying out the test setup with a ground plane measurement. Will do a nearfield measurement to see if things are working as they should.
PostPosted: January 8th, 2018, 12:07 am
The nearfield measurement of the upper woofer looks good, so off to building the second 2x12.
PostPosted: January 8th, 2018, 10:38 pm
The second 2x12 H-Frame is loaded with servo drivers. Now starts the last wiring. Both HX300 amps are working.
PostPosted: January 9th, 2018, 6:08 pm
Both subs are now running and measurements looks good. Now to experiment with the digital crossover for the OB planar head.
PostPosted: January 9th, 2018, 10:05 pm
What is the reason for reversing one woofer. I assume they are firing in the same direction
PostPosted: January 9th, 2018, 10:38 pm
Yes, both are firing the same direction.
From Sigfriend Linkwitz it helps lower harmonic distortion, if I am understanding the information. His W-Frames use the same concept.
PostPosted: January 9th, 2018, 10:49 pm
If you look at the photo you will see that one driver is pointed in the opposite direction from the other. If they were wired in phase one would cancel the other as the cones would be moving in opposite directions. By reversing the polarity of one in relation to the other the cones will move in the same direction at the same time. This does tend to reduce 2nd order harmonic distortion although I am not clear on the mechanism why that happens. In reality, the most important thing to do for distortion reduction is to keep the driver within XMax limits.
