I used to have the horn bug and lusted after Klipschorns, but never had a room with two good corners. Good luck on your quest.
In the early 70's I built some speakers (stereo then with a center fill channel). Each of the main speakers had 2 Altec 411-8a woofers, 511B horn + 808-8a drivers, Altec 3000H horn tweeter (back then I could actually hear it). I had a home made electronic crossover using 741 op-amps (I didn't know then that ac op-amps would have been better). The center channel was all Electo-Voice drivers (15 inch woofer, mid-range diffraction horn, and a diffraction horn tweeter). I don't remember the parts anymore. All three channels had the 3-way electronic crossovers. The amplifiers were kits from SWTP (Southwest Technical Products), the preamp a Crown IC150, and the turntable a Empire 598 with a Shure cartridge. Roscoe has all the Altec horn hardware of mine unless he has passed it on. Those were the good old days. I still build speaker kits but not electronics anymore. Eras change and know I concentrate on digital signal processing for crossovers. My current and future system consists of -
Current Audio Visual System:
Subwoofer (Two subwoofers):
Dayton Audio SPA1000 1000W Subwoofer plate amplifier
Dayton Audio RSS460HO-4 18" reference HO subwoofer 4 ohm
Denovo 4 cubic foot cabinet.
Main Speakers (Stero Pair Bi-Amplified):
CBT36K Line Array Speaker Pair Kit
Emotiva XPA-4 Gen 3 Amp (4 channels, 350 W per channel)
miniDSP 2x4 HD (dsp crossover)
Preamp:
Emotiva UMC-200
HTPC:
Old:
Ubuntu 16.04 (operating system)
Kodi 17.4 (media server)
AMD AD3850JAHMBOX 3850 Quad-Core Socket AM1 1.3 GHz APU Processor
Asus M4A88T-M Motherboard
EVGA GeForce GT 740 2GB GDDR3 DVI/HDM/VGA Low Profile Graphics Cards 02G-P4-2740-KR
Cable Tuner:
SilconDust HD HomeRun Prime
Verizon FIOS
Projector:
Optoma HD25e
Screen:
Elite Screens Sable Frame, 120-inch 16:9, Fixed Frame Home Theater Projection Projector Screen, ER120WH1
Next Audio Visual System:
Main Speakers (Stero Pair Tri-Amplified):
DAC (3 alternatives):
Emotiva UMC-200 (hdmi audio input)
Xonar D2 (pci audio card)
SewellSoundbox Pro External 24 bit 192 KHz Audio, 7.1 Channels SW-30415 (usb input)
HTPC:
Gigabyte AM3+ AMD DDR3 1333 760G HDMI USB 3.0 Micro ATX Motherboard GA-78LMT-USB3
AMD FD6300WMHKBOX FX-6300 6-Core Processor Black Edition
Ecasound 2.9.1 (dsp crossover software)
Cable Tuner:
Verizon FIOS
Projector:
Optoma HD25e
Screen:
