It is currently July 6th, 2026, 1:35 pm
PostPosted: September 15th, 2017, 1:00 pm
The following link might interest those who use Raspberry Pi's for audio processing -
https://www.osaelectronics.com/product/dacberry-pro/
PostPosted: September 15th, 2017, 2:10 pm
looks really interesting
I think I will give it a try
thanks
PostPosted: September 15th, 2017, 2:16 pm
I'm not sure how much credence I'd give their marketing hype. They've got a 10WPC amp board too, that they claim is powered by the Pi. Let's see, a typical Raspbeery Pi power supply is 5V at either 2 or 2.5A. Lets give them the benefit of the doubt, and assume a 2.5A PS. So, we've got a power supply that can only supply 12.5W powering a 20W amp AND the Pi. That's not likely to work very well..... :angry-banghead:
It's also no the only Pi hat based on the PCM5242....
PostPosted: September 15th, 2017, 2:25 pm
I agree
but I do not care about the amp just the DAC and low level outs.
PostPosted: September 15th, 2017, 2:27 pm
the DOC's say 3 watt amp on board
PostPosted: September 15th, 2017, 2:28 pm
I agree
There a a LOT of DAC boards for the Pi... There's doesn't seem like anything special compared to the rest of the marketplace.
PostPosted: September 15th, 2017, 2:30 pm
From my post:
I was referring to another product of theirs. If they're going to give you a line of BS on one, they're probably going to do it for the entire line...
Rosoce
PostPosted: September 15th, 2017, 2:40 pm
Caveat Emptor re specs. I tested a Behringer iNUKE NU6000 stereo power amp that was rated at 3,100W/ch into 4 ohms and when it didn't meet specs I called them. They said that was "peak power" and the RMS output was 2,000W/ch. It clipped at 1,200W/ch and the only way to get 2,000 was to drive it so far into clipping it was essentially a square wave generator. However, at 1,200W/ch it behaved quite well and at a price of $350 it is a steal for a high powered amp. The only downside is that like most pro equipment it has fans.
PostPosted: September 15th, 2017, 4:25 pm
Online
From my post:
Rosoce
If more women understood that, there would be a whole lot fewer marriages.
PostPosted: September 15th, 2017, 6:25 pm
Maybe we should make it our mission in life to educate them. We could be heroes to generations of men to come :obscene-drinkingcheers:
Users browsing this forum: Stuart Polansky and 142 guests
