It is currently July 6th, 2026, 9:59 pm
 Post subject: Sheet Metal Cutter
PostPosted: July 17th, 2017, 12:18 pm
I caught an advertisement on television about the Versa Cutter and it appears that this gizmo can be the answer to easily cutting sheet metal. :thumbup:
Previously I had to use tin snips. UGH! A Saber saw or band saw is just as bad and awkward to use. :(
I ordered the Versa Cutter today and can't wait to get my hands on it. Here is the link:
http://www.versicutter.com/
I did some "homework" and found that an Australian industrial company invented the device and holds a patent for it. They are licensing it out and one on TV is the same one the originator sells with a different color. Also, you get a nice set of accessories with it that cost extra "Down Under."
BTW -- it's considered an alternative to a plasma cutter. COOL!
:D
 Post subject: Re: Sheet Metal Cutter
PostPosted: July 17th, 2017, 12:25 pm
If it works like the video then it will be useful as a bench tool.
Looks awkward as a hand tool.
PostPosted: July 17th, 2017, 12:34 pm
You might do better with this -
https://www.amazon.com/Milwaukee-6852-2 ... B000EP499E
than a cheap Chinese tool that will get dull quickly. I am wary of anything that is advertised on cable TV.
PostPosted: July 17th, 2017, 12:36 pm
Not Chinese. It is the exact same tool the inventors are selling with hardened bits.
PostPosted: July 17th, 2017, 12:50 pm
This tool is similar to what I used to call a nibbler.
It has a lot of advantages compared to a shear-type device, especially when working in tight confines.
PostPosted: July 17th, 2017, 12:51 pm
I have one of these, it works great.
PostPosted: July 17th, 2017, 1:29 pm
YUP! It is a nibbler!
PostPosted: July 17th, 2017, 3:10 pm
I have been using this nibbler for over 50 years and it works great. Slower than motorized but unless you have production work it is not a problem and much easier to use especially in tight places than a tool you connect to a drill.
http://www.aircraftspruce.com/catalog/t ... ngtool.php
PostPosted: July 17th, 2017, 4:00 pm
My hand aches just thinking about using a manual nibbler. OUCH!
PostPosted: July 17th, 2017, 4:33 pm
Wimp!
Users browsing this forum: No registered users and 148 guests
