It is currently September 16th, 2026, 10:32 am
PostPosted: August 2nd, 2013, 3:16 pm
TubeDriver wrote:
It is odd that monoblocks would fail at the same time. I wonder about a power surge that shorted a small cap across H and Neutral or maybe fried the SS rectification?
Exactly what I was thinking.... :clap:
PostPosted: August 2nd, 2013, 3:17 pm
I suspect a rectifier diode has shorted, ironically in each one. I am guessing this because they blow the fuse even if the tubes are not installed if I understand you, bigthinker, correctly. Perhaps a line surge during a storm took them out?
PostPosted: August 2nd, 2013, 3:22 pm
Looking at the photo, it is not clear if there is a cap between hot and neutral at the IEC, though I think I can make out a dark disc shape below the wiring. I agree that it is highly unusual for both units to fail in the same way at the same time, and an external event such as a power surge would be a logical cause.
PostPosted: August 2nd, 2013, 3:30 pm
I also noticed that disc shape near the AC input wiring. Could be a small value, cheap ceramic cap?
PostPosted: August 2nd, 2013, 3:35 pm
That is what I suspect. The only problem is that if they shorted, they should take the breaker with them when plugged in. So it kind of rules that out as a possibility, since the fuse blows when turned on.
PostPosted: August 2nd, 2013, 3:38 pm
Unless, and it's hard to tell from the picture, it's got one of those IEC receptacles with the fuse-holder built-in.... :confusion-confused: Need more :banana-gotpics:
PostPosted: August 2nd, 2013, 3:57 pm
Hate to stick my nose into these things, but..... Safe to assume both are correctly connected to a speaker load without any shorts in the wiring?
Jim
PostPosted: August 2nd, 2013, 5:24 pm
is it safe to assume that the poster does not have much electronics experience? If so, someone more knowledgeable may need to look at these...
PostPosted: August 2nd, 2013, 5:42 pm
Probably. Patrick - I should be available pretty much any time Sat, and Sun after about 1PM if you want to make the trek all the way out here...
Last edited by Roscoe Primrose on August 2nd, 2013, 5:43 pm, edited 1 time in total.
typo
PostPosted: August 2nd, 2013, 6:31 pm
I appreciate all the response to this post. I do not have a lot of experience but I do own an Ohm meter, so I can respond to some of your recommendations. I was thinking it was the mains transformer. If someone knows of a reputable place to get them repaired or knows for certain how to repair this, please let me know.
Again, thanks for all the positive suggestions and thoughts on this problem.
