It is currently October 16th, 2026, 7:01 pm
PostPosted: June 9th, 2016, 12:58 pm
Walt says that their air dielectric, plenum-rated stuff took his system to another level:
http://kvantefir.com/assets/files/pdfdownloads/Andrew_cable.pdf
Tells us more about using this as a speaker wire, Walt.? Which model exactly? Where did you get it from?
PostPosted: June 9th, 2016, 3:55 pm
I got lucky and nabbed a 100' bundle at a ham fest some 15 years ago and it just sat in my basement. I was using a cable I obtained from the Boeing Warehouse in Everett, Washington that I could not part with for some 20 years. I have tried many "audio" cables and the Boeing stuff was always the cable that served the music in a good way. Then I looked the Heliax through "new" eyes and did a temporary trial with alligator clips. HOLY CRAP!! It wasn't even a contest! So I terminated a pair -- and as Paul Ellicott said -- they are special. A buddy of mine has had the same experience. :thumbup:
I terminated them with male Silver PL-259 connectors and attached female PL-259 connectors to the floor of my living room at the amplifier and speaker ends. I run the cable under the floor. What can I say? I like things neat. The female is terminated with 8-inch twisted pig-tales up through the floor to the amps. and speakers.
So -- you could say that my house is now actually part of my audio system. :crazy:
Working with Heliax is another pain-in-the-ass. A thermal stripper, a plumber's copper-tubing cutter, together with a 250-watt vintage soldering iron gets the job done. You will not be able to solder with a soldering gun. You need some serious Btu's to overcome the heat sinking abilities of the copper-tubing shield and silver connectors. The big-ass iron will pump plenty of heat for good solder flow.
00 AA Heliax Speaker Cable Entering Floor.tif
PostPosted: June 9th, 2016, 3:57 pm
One of my pictures didn't go along for the ride -- here it is.
PostPosted: June 9th, 2016, 4:01 pm
Let's try this again after converting to <*.jpg>
PostPosted: June 9th, 2016, 5:07 pm
I bet they sound great playing the blues...
PostPosted: June 9th, 2016, 5:21 pm
The dynamic contrasts are way over the top. :thumbup:
PostPosted: June 9th, 2016, 6:46 pm
I tried some 1/2" heliax for interconnects and speaker cable. Now, that stuff is hard to work with. Bend radius is like two feet.
I didn't like it. It is all copperweld. Don't think they make any with solid copper center conductor. The copper outer "foil" is pretty awesome though. I tried using two runs, only the outer but that was absurd, mechanically. Kudos to Walt for being nuts enough to roll with it.
I also thought it sounded too dry with what I was using for speakers in my office at the time (Altec 755A)
There is German cable that is like Heliax but solid copper center, called Aircom Plus, I think. Haven't tried it.
I found a similar sort of cable, not hardline though, called "Aircell 7" that worked really really great as speaker cable and interconnect, but mainly speaker cable. Oxygen free copper center, foam PE with high air content, and copper foil outer. It was imported by SSB Electronics from Germany. Now obsolete and replaced by copperweld junk, I believe. I still have a run on the speakers in my bedroom.
A German audio dude I know who is also a ham says he can still get Aircell 7 in Germany.
These days I use recycled used Belden I bought on ebay from a dude who stripped it out of casinos in Vegas. Gettin' too old for crazy stuff. I'll leave that to you nerds! ;op
PS--Just checked the name...there is another cable from Germany called "Ecoflex" (SSB Electronic) that is stranded copper, highly foamed out PE, copper/PE foil and copper braid. Never tried it but my bud said it is a lot like Aircell 7.
Germans use a lot more solid copper center conductors than we do. Most intriguing RF cables turn out to be copper plated steel or aluminum.
PostPosted: June 10th, 2016, 9:56 am
I am using the plenum-rated version (blue) that is Teflon as opposed to the polyethylene version (black). The so-called copper-weld center conductor is actually copper-clad aluminum that is nominally 12-gage and has a high polish. If I find time today I'll strip out a piece and photograph it. Especially when listening to music with a pair of Quads, that I repaired for a friend, the sound was lush, musical, and had a silky transparency. Based on that experience I'd have to say the both the Quads and the Heliax stepped out of way and neither performed any editorial tricks. A very anal DIY audiophile friend has had the same experience and tried to second-guess my results by buying into the German stuff. He reported that he wasted his money and ended up using the Heliax.
PostPosted: June 10th, 2016, 10:39 am
I wouldn't doubt that the plenum version sounds different from standard Heliax. And it is always a question of system synergy, taste, whatever.
But I'm out due to the mechanical issues. Not user friendly. These days, I'm happy with 2 cond Belden or whatever is easy.
I'm also put off by aluminum but I recognize that this is due to some mental picture, not experience based research and testing.
I found that, especially for interconnects but speaker cables too, wires with hard plastic sounded hard and wires with soft plastic sounded soft. Got to really like PE, foamed or low density solid and soft outer jackets, even PVC.
For example,I tried many LMR series cables. Found these sounded a lot better stripped out of the hard outer jacket.
The Aircell 7 and Rg-223 I like both have soft PVC jackets, which helps with damping (or something). They also have a lot of copper inside. and I think the dual shield on these also helps with damping.
What constitutes "editorializing" is an open question. The sort of dry-ass sound that is typically lauded as "neutral" is editorializing to me! Semantics. Language. Can't let that get into the way of good music.
Used surplus Belden....now there is a neutral wire, neutral in the sense that nobody cares. :lol:
I also really like the WE 16ga AIW wire (tinned/PVC/cloth outer) that has been hipster trendy lately. I got turned on to this stuff the top WE guys in Japan 10-15 years ago. This wire is the reference for the folks at Tube Kingdom magazine. For the kind of speakers I use, that stuff seems to get out of the way, so to speak.
For horns and WE/Altec speakers, I like tinned. I used to use the WE/AIW wire a lot when it was dirt cheap. Now they sell it by the inch.
I think PVC is due for a come back. Teflon never convinced me.
PostPosted: June 10th, 2016, 11:59 am
The mental picture regarding aluminum was my problem as well. I kind of had buyer's remorse when I bought it at a Hamfest so I never even tried it until recently. My epiphany was the result of a conversation Tom P. and I had at Rosco's a while back and we got into a discussion about materials. Taken out of context -- Tom remarked that aluminum is not magnetic like ferrous metals after my comment that aluminum makes for a good Faraday shield. Then it dawned on me -- had I been technically asleep for a couple of decades -- WTF?!! Aluminum is almost as good a conductor as copper and Andrew surely had some solid reasons for manufacturing a micro-wave-capable cable using copper-clad aluminum for the center conductor. Speed and power handling was the reason -- or so I suppose. Looking at the data sheet -- the stuff is rated at 13-kW. YIKES! My Careys top out at 50-watts and my Altecs barely use that. It is also extremely low-loss cable at extreme frequencies and lengths. And for one example -- mine -- at 25-feet amplifier to speaker the D.C. resistance of my run is only 0.03525-ohms. Almost like no cable at all. At 500-kHz. 100-feet of the Heliax attenuates only 0.083-db.
When all is said and done -- now that I have crunched the numbers -- I can see why it has done such a remarkable job with mere audio. It passes on the edges of the complex wave-forms (aka. resolution) because of its extremely wide bandwidth. Same goes for the Phaseflex.
