It is currently August 25th, 2026, 4:12 am
 Post subject: Re: Hi
PostPosted: June 6th, 2016, 6:59 am
If those end up being too big,this is what was common when the gear was new. http://www.ebay.com/itm/Switchcraft-RCA ... xyIPNTdC93
PostPosted: June 6th, 2016, 8:54 am
And are you sitting down? Those original RCAs as created by RCA was used in television tuners and had -- wait for it -- here it comes -- a 75-ohm characteristic impedance. :crazy:
PostPosted: June 6th, 2016, 9:15 am
I have a boxful of diy cables. Mainly low mass, solid core copper with the cheapest, lightest RS connectors. You are welcome to take a pair. What length do you need?
PostPosted: June 6th, 2016, 1:37 pm
I've had great success with Belden 7502 and nickel-plated, extra-long Neutrik RCA plugs. I occasionally try fancier cables but keep coming back to this. Very open and neutral. Mouser sells the Belden for $300 for a 250 foot reel, about the same price and "budget" audiophile cables. You can make any lengths you want. ;-)
PostPosted: June 6th, 2016, 2:39 pm
I can't comment on RCA connectors as I don't know what would fit these HH Scott amps but there seems to be some good suggestions already. I use KLE Innovations harmony RCAs. 26 gauge 9999 pure silver wire in 4 AWG teflon tubes (part #5335K24 from mcmaster). That combination works very well in my system.
PostPosted: June 6th, 2016, 3:05 pm
Belden was the silent partner in the audio cable revolution many decades ago. I looked up the 7502. NICE!
What with the stranded copper conductor nestled in a "bed" polyethylene foam it's tough to go wrong.
PostPosted: June 6th, 2016, 5:45 pm
got a ton of those laying around...
PostPosted: June 6th, 2016, 5:46 pm
Thanks, at least a meter pair to reach from my table to the Scott...
PostPosted: June 6th, 2016, 5:49 pm
Thanks for all the help guys, its most appreciated! I am moving on those connectors, Walt, and another suggestions regarding the cable. I'm afraid a 250' reel of Belden would get me kicked right out of the house though...
PostPosted: June 7th, 2016, 12:04 pm
http://www.farnell.com/datasheets/1819673.pdf
