I built a pair of NX-3 Bravo Towers based on a GR Research kit that provided drivers, crossover parts, internal wire, etc., and cabinet plans. I successfully veneered the cabinet with walnut and am in the process of burning them in.
A detailed thread can be found at the Audio Circle site under the GR Research circle that is titled, "NX-3 Bravo Towers, Standard Build." <
https://www.audiocircle.com/index.php?topic=193991.0>
It's an MTM arrangement placed in a slim (8" wide) transmission-line cabinet. Sensitivity is 91dB, Nominal Impedance is 8 Ohm, and the Crossover is 950Hz. The base extends down to 40 Hz.
File comment: A Finished Speaker
