It is currently September 20th, 2026, 8:31 am
 Post subject: Re: Acknowledgement
PostPosted: July 6th, 2026, 1:41 pm
Agreeing with Grover. I've also had leakage issues with some, eight others have never leaked. Just grab a little epoxy and seal the ends. Problem solved and great sounding caps.
Grover had another cap recommendation that has worked well for me: Cornell Dubilier Knowles 942C series. Look for the highest voltage available.
https://www.digikey.com/en/products/filter/film-capacitors/62?s=N4IgjCBcoEwAwBYCcVQGMoDMCGAbAzgKYA0IA9lANohwB0YABAK0BiIpdYArM2x7TBi92NWggDswgLqkADgBcoIAKoA7AJbyA8pgCyhbPgCuAJ0IgAvqQC0MVCAyR5JoyXJUQXEFKshrEaAcsPCJSCkhqAGZIgA5vX2sEe0ccAjdw6jA4JG54iwsgA
The catch is, they don't sell a 0.33uF. Depending on the circuit, you may be just fine with a 0.22 (LF Rolloff?)or 0.47 (stability?) Or, you could parallel a 0.1uF & 0.22uF.
PostPosted: July 6th, 2026, 2:30 pm
Well, if you're going to try the Cornell-Dubiliers you can go up to 1uF. The only reason I recommended the smaller Miflex is because the 1uF's are just so enormous. They won't fit on the board but you could off-board them to a terminal strip. But they're also pretty expensive.
PostPosted: July 7th, 2026, 10:51 pm
I will get to upgrading the caps eventually. Have a couple of higher priorities.
As I am running audio thru HQPlayer upsampling, intend to try out room correction with HQPlayer’s convolution engine.
Just installed Linlai WB2A3s, I got from China-hifi-audio. They are driving the mid horns from 700Hz to 2400Hz. They do bring life-like quality to vocals.
PostPosted: July 31st, 2026, 12:02 pm
Here is a light edit that polished the flow, corrected minor typos, and leaned slightly into audiophile terminology while keeping your exact voice, structure, and tone completely intact:
Since I got the Tubes4HiFi VTA SP14 preamp about three months ago, I’ve been having a blast with audio again—it’s been a welcome distraction from life.
I've made numerous changes and improvements to the system recently, with a couple of key lessons learned along the way:
Holo Spring 3 R2R DAC performs significantly better with a PCM signal at 1.4112 MHz compared to 705.6 kHz.
As of now, I actually prefer PCM 1.4112 MHz over DSD1024. I’m finding DSD to be a bit "polite" by comparison—though obviously, I need more long-term listening sessions to really nail down the subtle nuances.
HQPlayer elevates the entire system. Using it for upsampling has proven to be perhaps the best bang-for-the-buck upgrade. Going back to standalone Roon (no oversampling) sounds "crude" in comparison.
My prior experiences with DSP were disappointing, but I recently tried HQPlayer's convolution engine for room correction, and I am completely sold. I couldn't detect a trace of signal degradation—instead, I notice better texture, details, and soundstage. It's a fantastic tool; definitely worth trying out even if you're running traditional box speakers.
PostPosted: July 31st, 2026, 7:49 pm
Thanks for the update! Glad things have come together and you're enjoying your system!
PostPosted: August 1st, 2026, 12:19 pm
Thanks Grover.
As you can tell, I am obviously excited. My system never sounded this good.
PostPosted: September 9th, 2026, 7:24 pm
Audiophiles are crazy....
This is SP14 preamp with Linlai Grant Fidelity 6SN7 tubes. Tubes are so large, I had to stack 2 socket savers...
:lol: :lol:
PostPosted: September 9th, 2026, 8:11 pm
It took you this long to figure that out :confusion-confused:
PostPosted: September 9th, 2026, 11:24 pm
Our wives are happier that we are Rabid Audiophiles and not chasing skirts and getting drunk. :text-yeahthat:
