It is currently July 21st, 2026, 11:52 pm
PostPosted: January 28th, 2015, 10:22 am
??? So I cannot use the Monarchy DIP AES/EBU output with an S/PDIF input? I have to use a balun?
PostPosted: January 28th, 2015, 11:05 am
You can but the results will not be as good. I just checked on ebay and Canare baluns are listed for less than $8. Doing it the other way may cost you more when you figure in the parts and connectors and result in inferior performance. See the listing below.
http://www.ebay.com/itm/Canare-BCJ-XP-T ... 35e45963e3
PostPosted: January 28th, 2015, 11:20 am
What, internally, is the deficit in the Monarchy DIP? You are saying that the reclocking and internal conversion from S/PDIF to AES/EBU with an XLR connector is deficient and better replaced with an in-line transformer? Are you familiar with the Monarchy?
The "other way" involves the DIP, which I already own, so its $150 or so price tag is not an issue. What other parts are there? I need an XLR-XLR interconnect in either case.
Confused in Brentwood.................
PostPosted: January 28th, 2015, 12:15 pm
Sorry Stuart. I misunderstood. I didn't realize you were going to do the conversion internally. I thought you were going to connect a SPDIF output from one device to the AES/EBU input of another. In that case, a balun is the best way to go. If you are going to do the conversion internally in the first unit and feed the signal out via a matching protocol to the second you only need the appropriate interconnect cable to complete the job.
PostPosted: January 28th, 2015, 1:22 pm
Thanks Tom!
PostPosted: January 28th, 2015, 6:53 pm
Stuart,
I have made several AES/EBU cables with some 110 ohm Belden Twinax (Plenum and non-plenum versions) Like - http://www.belden.com/techdatas/english/89207.pdf and Neutrik XLRs
Very happy with the results...and you are welcome to try them.
Also, the DIP is a very good way to do the conversion to AES/EBU. I also have the Meridian 518 available, which gives you 24 bit digital volume control... :handgestures-thumbupleft:
PostPosted: January 28th, 2015, 9:09 pm
You may also wantr to try Belden 1800F. It is specifically made for AES/EBU transmission. In addition it is flexible and has a french braid shield which is a joy to work with. The cover is a matt finish which also looks very good. I have a roll if you would like to try some.
http://www.belden.com/techdatas/metric/1800F.pdf
PostPosted: January 30th, 2015, 5:39 pm
Yes, please! I would like to try some!
I assume that, cable wise, it is best to keep the DIP (clock) as close to the USB/S/PDIF interface as possible, maximizing the run of balanced cable? In other words, short unbalanced runs and long balanced runs.
PostPosted: January 30th, 2015, 6:24 pm
Yup, balanced is the way to go for longer runs.......
Do you still have Linus at the "other end" of the room?
PostPosted: January 30th, 2015, 6:40 pm
Linus?
Not sure to what you refer.
However, I am thinking of putting the server atop the rack. Do you think that will be an issue? The monitor would be alongside the turntable. I know, blasphemy. I'm concerned about noise, though.
Users browsing this forum: No registered users and 189 guests
