It is currently September 25th, 2026, 8:29 pm
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 20  Next
PostPosted: February 17th, 2021, 11:19 am
Pete,
Why don't you try it out on the Pi I lent you. I gave you an extra SDCard, just blow that away and try VitOS and report. The next thing you need is a better power supply for the RPi4. All my 5V LPS are tied up in my system, however, I believe I have a iPower 5V 3A switcher, and a iFi DC Purifier 2 that should clean up the supply more than the generic switcher supply I provided with the Pi. You can try that. OR, I have a battery pack that with the iFi DC Purifier 2 could provide clean power for the Pi, at least while the battery lasts. You are welcome to try that as well.
PostPosted: February 17th, 2021, 11:25 am
I'll try the VitOS. Maybe grab that ipower SMPS at some point. Thanks again.
Pete,
PostPosted: February 17th, 2021, 11:55 am
Pete,
Just checked, and my iPower SMPS is only rated at 2.5A rather than the 3A needed by the RPi4. It may have problems with supplying 5V to the Pi under heavy current demands (the Pi will fail to boot if the power supply does not meet min voltage). I do have a 5V/4.3A SMPS that with the iFi DC Purifier 2 should provide most of the benefits of the iPower SMPS. I was using the iPower SMPS + DC Purfiier 2 in series for a while on the Qutest.
PostPosted: February 17th, 2021, 3:41 pm
No worries. I have a Keces P8 enroute, so will see what that does for my Nucleus.
Pete,
PostPosted: February 17th, 2021, 4:25 pm
Does the Keces P8 have enough current on the 5V USB output to power an RPi4? Looks pretty good for powering a Nucleus, that I am sure is a step in the right direction.
PostPosted: February 17th, 2021, 4:30 pm
Pete,
On another note, I am finishing up the second Pass Amp Camp Amp in the next couple of days, and will have them run as monoblocks. Welcome to borrow them (and my Hybrid stereo amp) if you would like to listen to them sometime.
PostPosted: February 17th, 2021, 7:02 pm
Unfortunately no. It is 5v 1A out and a 19v 10A output. I sort of wonder if I should have gone for the Plex300 which had 12v, 19v and 2 adj out 1-5v. The Keces just looked nicer for the Nucleus. Oh well, maybe get plex300 at some point to use as an experimental PS if I keep messing with stuff.
PostPosted: February 17th, 2021, 7:04 pm
I will certainly take you up on this offer, thanks. I have had my eye on the Camp Amps for a while. Listening to your pair in my system would really help me to make a decision. :obscene-drinkingcheers:
Pete,
PostPosted: February 17th, 2021, 7:38 pm
Pete,
The ACA are a fun little build, and the first one I built sounds pretty good at my music workstation driving my Aria 5R monitors (4 ohm, 95 dB) in stereo mode. Sounds like a SE tube amp (it is a SE Mosfet amp, of course) I did one upgrade on the output coupling cap but otherwise stock. A good weekend (or two weekend project if you stretch it out).
PostPosted: February 19th, 2021, 1:40 pm
Did you build this version of the ACA https://www.firstwatt.com/pdf/art_amp_camp_1.pdf or is there a later version?
Users browsing this forum: No registered users and 102 guests
