It is currently November 20th, 2026, 6:00 am
 Post subject: Re: Video card crashing
PostPosted: August 19th, 2020, 8:22 pm
Any other recommendations on cases, as well as motherboards? I normally use Antec cases and Asus motherboards.
PostPosted: August 19th, 2020, 10:55 pm
Check out Cooler Master cases -
https://www.coolermaster.com/catalog/cases/#!/
PostPosted: August 20th, 2020, 7:39 am
I like Coolermaster also I feel they are definitely worth the few dollars more cost over Antecedent. They are just better made.
PostPosted: August 20th, 2020, 12:24 pm
He are two Cooler Master cases I have. The large one is my main computer and has 8 hard drive in it (room for fourteen including hot swap). The smaller (still large) is one of my HTPC machines. Both cases have two hot swap drive slots and two optical drive slots.
and lots of quite fans.
One of the reasons I have large cases is that I like to play with the guts of my machines (I built both of them) modifying (swapping sound and video cards) them and access is very easy on these cases. Note that no tools are needed for installing hard drives.
PostPosted: August 22nd, 2020, 4:13 pm
As a side note: I just noticed that the bottom front of the case has a screen filter. I never knew either case had that. I cleaned one. Will work on the other later.
I will look at the new cases recommended. Any motherboards recommendations?
PostPosted: August 22nd, 2020, 5:53 pm
There are plenty of free utilities that monitor CPU temperature
Modern club's throttle back if they approach 80 C
PostPosted: August 22nd, 2020, 6:03 pm
Pick a cpu then pick a motherboard. I like AMD Ryzen cpu's. Here is an example -
https://pcpartpicker.com/b/pzQZxr
PostPosted: August 27th, 2020, 2:51 pm
If you have an operating system on one hard drive, can you copy it to another drive and it boot up?
PostPosted: August 27th, 2020, 3:52 pm
Depends on how you copy it... If you just copy the files, no. If you do a complete disk copy, probably. Of course, if it's Winblows it probably won't be activated after you copy...
PostPosted: August 27th, 2020, 4:06 pm
If it is windows it has to be the same motherboard and cpu that the original hard drive was attached to and you copy the disk image. If the motherboard or cpu change you need to install windows from scratch and then copy your files (not the windows files). You can only install the copy of windows you have on a new system from the installation dvd or flash drive if it is portable. If is an OEM copy you are out of luck.
