It is currently June 24th, 2026, 10:34 am
PostPosted: May 8th, 2014, 8:40 am
http://www.ebay.com/sch/oldssx455/m.htm ... 7675.l2562
PostPosted: May 8th, 2014, 11:15 am
Thanks for the GM70's Joel.
Soliciting advice on a design for push-pull Class A GM70 amplifier!
Even a measly 100 watts Class A will make me quite happy!
I've read a 5k PP load is about ideal......
I know a high current driver is needed, but beyond that.........
PostPosted: May 8th, 2014, 11:26 am
Even though you are planning class A, I recommend a mosfet source follower driver.
PostPosted: May 8th, 2014, 11:30 am
my original plan was a diff 6SL7 direct coupled to a diff 6sn7 cap coupled to the mosfets.
But I'm going to be an uncle soon and need to raise money for plane tickets
PostPosted: May 8th, 2014, 4:24 pm
So, the "standard" Tubelab driver I've been working on will work? Guess I better do some data sheet reading! ;)
