It is currently February 5th, 2026, 1:24 pm
 Post subject: Cat Vomit Special
PostPosted: September 24th, 2019, 7:10 pm
Hey Ray,
Can you share your opinions of the 6C33C SET you built, especially compared to other SETs?
https://audioratbag.blogspot.com/2015/01/cat-vomit-special-6e5p-6c33c-parafeed.html
 Post subject: Re: Cat Vomit Special
PostPosted: September 25th, 2019, 9:18 am
I brought the amp along to Roscoe's place a few years ago where it was outclassed by David B's 845 amp but you would have to expect that. However, it did better than my 829B lightbulb amp which I also brought along. It was more dynamic which is the only way to describe it.
My subsequent GK-71 amp was much superior to the 6C33 with much more detail. It's the only amp I have made where electric guitars sound real to me with a bite that my other amps can't achieve. Not that I listen to electric guitar music all that often. I do not know why I get this impresssion. It could be one of a number of variables.
I also breadboarded this 6C33C cathode follower OTL using a stack of 48V SMPS units. It worked, but the power output was so low that I couldn' see developing it further. In addition, I am not a devotee of the 6SN7.
http://www.audio-talk.co.uk/phpBB3/viewtopic.php?f=11&t=7265&sid=d64b7cfa0f4c7f1b6f7d13e2f0822954
My 6C33C amp produced a lot of heat. Eventually the radiation of the big plate resistors started to blacken the wooden top plate. The tubes seem to have a limited life span before they get noisy and I have found that the tubes coming from the Ukraine are sometimes noisy on arrival, and yes, I go though the pre-conditioning process.
Late last year, I disassembled most of my amps in preparation for our move to Australia. Because of the time it takes to get a visa for my wife, we now expect to move in the June - August timeframe next year. I may or may not reassemble the amp because the climate is similar to Key West.
In the meantime, my health continues to improve, though slowly. This afternoon I go to Johns Hopkins where they will talk to me about doing IV IG treatment.
https://www.uptodate.com/contents/intravenous-immune-globulin-ivig-beyond-the-basics
Occasionally I work on my 6SK17-V - 45 amp which I am breadboarding. I may start a thread soon since I am trying some new things. My health problems have restricted the weight I can carry so I am trying to make it as light as possible. I lashed out when purchasing the output transformers and paid almost $20 for the pair of them.
https://www.amazon.com/gp/product/B0789CMD82/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
Obviously I don't expect monster bass out of them. I will use them eventually with the PRV 5MR450-NDY speakers when I have the strength to assemble them. You might remember the bloke in the UK who used them in suspended fashion. Instead of the heavy Dayton woofers I will use the cheap and lightweight GRS high QTS 15" woofers. I am planning to use bungee cords to suspend the speakers from 1" plastic water pipe.
https://www.lencoheaven.net/forum/index.php?topic=31371.15
So I may be somewhat incapacitated right now, but I still build.
