It is currently November 27th, 2026, 11:40 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 147 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 15  Next
PostPosted: December 28th, 2018, 3:18 pm
Brombo, you have a PM
PostPosted: December 28th, 2018, 9:05 pm
I ordered the rest of the parts.
10 crossover parts
2 bags of polyfill
2 binding posts instead of the spring loaded ones
PostPosted: December 29th, 2018, 8:54 am
Good job! You won't be sorry. Great pride in turning a pile of parts into a nice sounding finished project.
PostPosted: December 29th, 2018, 12:20 pm
10 crossover parts
2 bags of polyfill
Just a note on fill. I found that polyfill is reactive and nowhere near as effective as wool or fiberglass. I know you already ordered the polyfill, but I feel you'll get a better result if you use wool or fiberglass.
PostPosted: December 29th, 2018, 12:54 pm
10 crossover parts
2 bags of polyfill
Fiberglass will not work in this application. Goal of the fill in this application is to dampen the resonances without hindering sound waves passing thru the transmission line. That needs playing around with the density and amount of the fill. Polifill is perfect for adjusting the density.
PostPosted: December 29th, 2018, 1:14 pm
10 crossover parts
2 bags of polyfill
As is fiberglass and wool. ??? Polyfill is reactive -- meaning it does a mediocre job when the goal is to dampen. Stuffing pillows -- you bet. Most speaker manufacturers other than the anal high-end guys use polyfill because it is cheap and does not create issues that OSHA might be worried about.
I am not talking about ridged fiberglass, but the stuff similar to that used for attic insulation. There was a time where fiberglass was the material of choice for U.S. speaker manufacturers and wool the choice of U.K. manufacturers. Wool is still desired to this day -- fiberglass not so much. Fiberglass friable fibers get everywhere and it is always advisable to wear a face mask and clothes you won't mind throwing out if you get frisky with the stuff.
Another material that I found extremely good and easy to work with is raw cotton right off the plant. At one time fabric shops carried it. No more. You still may be able to obtain raw cotton on eBay. Given a choice between raw cotton and the others -- cotton goes to the top of my list.
PostPosted: December 29th, 2018, 1:33 pm
Interesting information.
https://stason.org/TULARC/entertainment ... t-wit.html
https://www.diyaudio.com/forums/multi-w ... inets.html
https://www.qtasystems.co.uk/articles/h ... amping.htm
PostPosted: December 29th, 2018, 2:18 pm
For sealed boxes there is this. Don't know of relevance to vented enclosures.
http://bgavinsound.com/Reference/Speake ... hermal.txt
PostPosted: December 29th, 2018, 3:15 pm
When I receive the stuff, how do you install/mount them?
PostPosted: December 29th, 2018, 4:57 pm
These boards are what I used for the egg crossovers. They come in different colors and sizes and make placement of the individual components easy. You can also drill holes at the corners for spacers and screws to mount them inside the speaker cabinets.
https://www.parts-express.com/white-per ... 7--260-190
