It is currently August 22nd, 2026, 3:01 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
 Post subject: Re: Daphile software
PostPosted: August 21st, 2018, 4:25 am
Grover Gardner wrote:
You mean you are going to rip the CDs using Daphile? I would use standard FLAC at 5-6 compression. You can also play CDs directly through Daphile by loading the CD Player plugin.
If I set it higher, will it be better or is 5/6 the sweet spot?
PostPosted: August 21st, 2018, 11:33 am
That's the standard compression level on most rippers. Any less compression and you're just taking up disc space you don't need to.
PostPosted: August 21st, 2018, 11:47 am
I'm using the max at "8".
PostPosted: August 25th, 2018, 1:52 am
This PC I am using does not have wireless.
Are you able to connect the PC to an access point via wire so you can connect a tablet via wireless?
PostPosted: August 25th, 2018, 6:28 am
Yes, that’s how mine is setup...
PostPosted: August 25th, 2018, 1:10 pm
Not a wireless router, an access point.
PostPosted: August 25th, 2018, 7:40 pm
If it can get on your network, it ought to work. A USB WiFi dongle might be another option, that's how the one I setup for my Dad works...
PostPosted: August 30th, 2018, 3:17 pm
How do you rediscover it? I can't connect to it via network.
PostPosted: September 9th, 2018, 7:26 pm
Need help. Can't cut/paste music from an external USB drive to one of my internal drives.
PostPosted: September 9th, 2018, 7:51 pm
The file manager in daphile sucks.... It's probably easier to have daphile share the internal drive, and mount it on another computer and copy over the network...
