It is currently October 14th, 2026, 12:51 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
 Post subject: Daphile software
PostPosted: August 20th, 2018, 12:20 am
I got it to work via USB bootable but somehow I am missing a step on loading it onto the hard drive.
PostPosted: August 20th, 2018, 1:17 am
Got it loaded.
No sound when song is playing via web interface audio player. Have sound via web interface file manager and via Windows Explorer network.
PostPosted: August 20th, 2018, 9:22 am
mix4fix wrote:
Got it loaded.
What audio player are you trying to use? Did you install the DLNA/UPnP plugin?
PostPosted: August 20th, 2018, 11:33 am
Daphiles's built-in one.
Do I need that plug-in?
PostPosted: August 20th, 2018, 12:15 pm
No, not for the built-in player. What sound output are you trying to use--USB? In the main player window, did you select the playback device in the upper-right hand corner? (I think that's where it is...)
PostPosted: August 20th, 2018, 1:37 pm
The output selection is on the lower right corner. There are also lots of selections for output parameters under settings. Not all of them are shown in the screen shot. I use it to drive the USB input to my DEQX Express II and it works very well.
PostPosted: August 20th, 2018, 3:08 pm
What is the DAC you are trying to play to?
PostPosted: August 20th, 2018, 4:03 pm
Not hooked up to system yet. Logged in from my PC to that PC.
Need to reload music. I will hook up a USB Disc drive. When I load the CDs, is there a music file type I use?
PostPosted: August 20th, 2018, 7:07 pm
You mean you are going to rip the CDs using Daphile? I would use standard FLAC at 5-6 compression. You can also play CDs directly through Daphile by loading the CD Player plugin.
PostPosted: August 20th, 2018, 10:23 pm
The DACS are internal to the DEQX Express II that is my master control for both analog and digital input, crossover functions, time alignment, parametric EQ, etc.
https://www.deqx.com/products/hdp-express-ii/
