ratbagp wrote:
To change the subject slightly. In many parts of the world, installation of solar panels and batteries is increasing rapidly. Most systems are still connected to the grid but some are off-grid.
If you were to install either system, what would you do to maximize the quality of electricity used by your amplifier?
I'd install a 48Vdc battery system as part of the solar system and run the stereo directly off the 48Vdc supply.  There are some decent pure sine wave inverters out there if you insist on running things on 120Vac, you'd just need to do some research.  If most of your household ran on DC, you could even run a separate inverter for each piece of equipment requiring 120Vac;)
Ham radio sites are a good place to start on the research, we don't like RFI any more than audiophiles
