        September 7th, 2017, 10:07 pm
			STEP 00: Level TT
 - Flat un-modulated LP w/ball-bearing
STEP 0: Validate iRIAA is accurate
 - MLS with Hagtech iRIAA
 - Channels match ?
STEP 1: Mount the cartridge in the head-shell
 - Use "good" mounting hardware (stainless)
 - Mount the cartridge loosely in the head-shell.
 - Snug one side ( allow cartridge to pivot )
 - Avoid torquing tonearm bearing.
STEP 2: Attach leads to cartridge pins
 - Leave phono-cartridge cover in place
 - Be careful - many cartridges are broken in this step
 - Use tweezers or small needle-nose pliers
 - Expand leads with toothpick if too small
STEP 3: Set VTF (vertical tracking force).
 - Use MFR highest recommended value
 - Use Shure to get to ballpark
 - Finish with digital ( + Wally LP disk level tool)
STEP 4: Use geometry tool (Lofgren, baby)
 - Verify P_to_S distance for arm is 100% accurate [ <0.01mm all is lost if not done]
 - 1st Dennessen
 - 2nd Feickert
 - 3rd (Final) Wally
STEP 5: SRA
 - Optional -- measure cartridge height and use Wally cartridge skid as starting point  ( you are dismounting cartridge -- go back to STEP 1)
 - Raise/lower rear of tonearm
 - Use Dino-Lite digital microscope to measure SRA angle
 - Aim for 91 degrees
STEP 6: Azimuth
 - Mirror -- thickness of 180g LP
 - Fosgate  Fozgometer
 - O'scope -- Test LP's 1Khz at different points
 - Feickert Adjust+
STEP 7: Anti-Skate
 - Flat un-modulated disc
 - Wally AS tool
STEP 7: Tighten Screws
 - Tighten just enough to allow playing
STEP 8: Listen to music
 - Voice
 - Bass
 - Treble
 - Stereo Separation
 - Stereo Spread (Sound field)
 - Imaging
STEP 8: Iterate over STEPS 3-8 until perfect
STEP 9: Tighten Screws
 - Tighten with calibrated WIHA torque wrench (0.4 mn)
STEP 10: Wait for next Audio-club meeting where everybody tells you it is off/wrong
 - Get the handgun and shoot them in the dick
        September 8th, 2017, 5:25 am
			Love it, your hammer is dead center
	        Powered by phpBB © phpBB Group.
		    phpBB Mobile / SEO by Artodia.
