It is currently November 3rd, 2026, 2:42 am
PostPosted: May 24th, 2017, 2:33 pm
I'll know more soon :confusion-confused:
I still need to build the other one ;)
Which one do you like better?
PostPosted: May 24th, 2017, 2:46 pm
The SLOB. It's built so the main baffle is easily replaceable, I plan to try it with the 414/802-32B on a baffle at some point. I also have 12" co-axials by University, Tannoy & B&C to try, along with an 8" co-axial and several 8" full-range drivers. So many drivers, so little time ;)
PostPosted: May 24th, 2017, 5:59 pm
These pics are a little overdue, but here they are anyway.... I made the wings a bit deeper, and rounded the corners to help me avoid injury (again) :sad-roulette:
I also changed the subs to the Dayton PA-465s, which have a larger Xmax & a bit higher qts, the bass is quite a bit more solid now. I could live with these for a while :obscene-drinkingcheers:
PostPosted: August 31st, 2017, 9:51 am
Sometimes it's the simple things that make a huge difference...
Before adding the dowels as cross-braces the wings flapped so much with low bass playing that you could see it, now you can barely feel it. I think I'm going to need to redo the bass EQ now ;)
PostPosted: September 2nd, 2017, 8:07 pm
Yes, there is a huge improvement in the bass since I was there few months ago......
 Post subject: Roscoe's SLOBs
PostPosted: October 22nd, 2017, 11:21 am
Going to move the posts specific to my SLOBs here from the What do you know about SLOBS? thread, and add new ones as more development occurs..
 Post subject: Re: Roscoe's SLOBs
PostPosted: October 22nd, 2017, 8:17 pm
OK, so I'm not the guy you need to see about finishing wood... But, I think they look a bit better than bare plywood...
PostPosted: October 24th, 2017, 7:19 pm
Ok, back together after a second coat of stain on the baffles. Hopefully we won't scare anyone away this year just based on cosmetics alone....
PostPosted: October 24th, 2017, 9:27 pm
Looks good to me. Ready for the show!
Users browsing this forum: No registered users and 83 guests
