It is currently November 3rd, 2025, 3:33 am
 Post subject: Re: Technical Meeting?
PostPosted: August 8th, 2013, 12:06 pm
TubeDriver wrote:
This McGown amp is using global feedback (4 ohm output tap is connected to driver). Probably not needed for UL operation but better for triode mode I guess? Can any PP guys here comment on what has sounded better in their opinion (UL with or without global feedback, triode with global feedback, triode with no global feedback etc). I'll probably play around a bit and see what I prefer but I would think that output stage output impedance would be really high with a pentode operated in triode without feedback? Too high?
Triode connected pentodes have plate resistances comparable to "true" triodes, for example, the 6L6GC has a triode connected plate resistance of 1700ohms, which is about the same as a 45...
We've probably hijacked this thread enough at this point, if you want to continue this discussion, it probably ought to have it's own thread...
PostPosted: August 8th, 2013, 12:09 pm
Roscoe figured it out, per usual. :ugeek:
The toggle switch is a lever, with a pivot somewhere in the middle.
Visualize what the bottom half of the lever is doing......
TubeDriver wrote:
Unless I am completely misreading the wiring on the switch?
It is a 3 pin, 2 position switch. Pin 1 has a UL tap going to it. Middle pin goes to Grid 2 (resistor in series). Pin 3 leads to the primary. Switch towards Pin 1 is UL and switch toward Pin 3 is triode mode?
PostPosted: August 8th, 2013, 12:12 pm
Makes perfect sense!
PostPosted: August 8th, 2013, 12:17 pm
That makes sense and probably accounts for much of the gain loss (transformer primary is now too high)?
Will start new thread if I have any more questions.
PostPosted: August 8th, 2013, 8:02 pm
See new topic thread.
PostPosted: August 10th, 2013, 12:27 pm
Are we still planning a meeting for next week?
Craig
PostPosted: August 12th, 2013, 9:43 am
I have not heard of a lot of interest here. What happened to Mr. Antique Sound Labs? Is anybody else interested in such a meeting as an observer, or just to listen to some tunes and drink beer? One issue is that I don't have central air conditioning, so if it is supposed to be a hot weekend we should postpone.
PostPosted: August 12th, 2013, 10:05 am
I have my dead Dynaco ST-70.
Craig
PostPosted: August 12th, 2013, 12:26 pm
Looks like Roscoe has got the Antique Sound Labs worked out, so perhaps I could simply take a look at your ST 70 without the group get together if you like, Craig.
PostPosted: August 12th, 2013, 12:53 pm
I'd appreciate that. I have no clue where to begin. It hasn't been plugged in & hooked up in about 6 years.
Craig
Users browsing this forum: No registered users and 74 guests
