It is currently December 8th, 2025, 2:38 pm
PostPosted: December 9th, 2016, 8:33 pm
Looks like you got your answer, and that answer is no...
PostPosted: December 10th, 2016, 11:27 am
Call them back -- the question to ask is: What is the current rating of the 6.3-volt filament secondary winging of the power transformer?
Knowing that -- you can inventory the tubes on that filament winding and using tube data add up the total current. If there is at least 20% wiggle room left (using the KT-66s) then you are good to go.
A CYA move would be to fuse protect the filament supply to assure against an unwanted surge. Vintage power transformers are not readily available and may be expensive.
Users browsing this forum: No registered users and 74 guests
