It is currently December 8th, 2025, 2:16 pm
PostPosted: August 1st, 2016, 11:05 am
I have this board setup:
http://www.diyinhk.com/shop/audio-kits/ ... nd_led_pcb
and this one
http://www.ebay.com/itm/Assembled-AK449 ... 1771770440?
The USB portion does need a regulated 3.3V supply, so we'll be building that. I see that you didn't use a 5-pin connector, just individual wires. Okay, I just need to find a few of those. The other end is simple: just solder directly to the board, the header comes uninstalled. :D
PostPosted: August 1st, 2016, 11:50 am
You might be able to use the 3.3VDC regulator on the AK4495EQ DAC board to drive the USB board. It is the LT1085CT-3.3V 3A regulator that should have more than enough capacity to drive the XMOS chip as well.
The TO220 IC case can be heatsinked easily on these boards.
PostPosted: August 1st, 2016, 11:59 am
Good idea, that would be helpful; one less task! although I'm most concerned about software and Windows or Linux, depending.....
If I'm in enough trouble, I'll show up at your doorstep, but not after 1:00AM.
:lol:
PostPosted: August 1st, 2016, 12:06 pm
The USB board has the Windows OS USB driver to download. Spotted it when I looked.
Just start with Foobar2000 as the music player and the instructions to get it running on a PC look correct at the website.
PostPosted: August 1st, 2016, 12:08 pm
I will do that.
Read through the instructions a couple of times.
Already have Foobar2000, we'll see where that goes, with the add-ons.
Was hoping to implement the Daphile setup Roscoe had at the show, but one step at a time!
PostPosted: August 1st, 2016, 12:11 pm
Just remember if you have the DSDIFF component installed in Foobar2000 to remove it before installing the DSD components. They interfere with each other.
PostPosted: August 1st, 2016, 12:16 pm
No idea what that component is (doesn't really matter as long as it works), but now it's written on the back of my hand, like a cheat sheet!
PostPosted: August 1st, 2016, 12:23 pm
DSDIFF is the component that takes DSD *.IFF files and downsamples them to PCM to playback on any DAC.
To playback Native DSD mode files, you need to do the instructions on the USB board website.
PostPosted: August 1st, 2016, 7:18 pm
I received my AK4490 DAC board, complete with XMOS USB receiver card, digital display showing input and sampling rate, and switch for selecting optical/SPDIF/USB. Wired it up with recommended power transformers (2x9V, 10W each + 12-0-12, 10W) and it is playing! First impression is that this is a very liquid sounding DAC, using 44.1K/16 input from my music server thru the USB interface. No digital hardness or glare. I am going to play around with it (replacing the opamp with a Burson module) and also try some hi-res material, perhaps try upsampling to the unit if it does not already do that internally.
Damn great for less than $100 in parts.
PostPosted: August 1st, 2016, 7:47 pm
Does not the Burson's draw quite a bit more current than the IC's
Users browsing this forum: Bing [Bot] and 69 guests
