Thanks for the input.
Tom, I'm going to pass on USB-S/PDIF. I have that now, would like to eliminate S/PDIF from the system.
Roscoe, HAL, if I understand correctly, the CS8414 serves to change the S/PDIF (in my case the balanced version) to the I2S protocol?
The DAC chips are BB PCM63. There are two other on board chips.
I don't have a super clear schematic. The DAC 60 is similar to my DAC 50, may be more legible.
Pictures are attached from when I replaced the Toslink input with a transformer, per Crystal's data sheet on the chip, to allow balanced input. Attaching both schematics. Will have to do multiple posts due to file attachment limits.
Does this help?
