It is currently October 12th, 2026, 2:06 pm
Post new topic Reply to topic  [ 393 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 40  Next
PostPosted: April 9th, 2016, 9:38 am
Sorry for the spellchecker errors!
PostPosted: April 9th, 2016, 9:54 am
If I can get them, 8- NEO10's and 22-NEO3PDR's per side. Each NEO10 and each pair of NEO3PDR's will have their own amp modules for beamforming. Only time will tell if they are available.
PostPosted: April 9th, 2016, 11:05 am
Tough to find them in a #4 size screw around my area. I do use hex heads for the larger ones.
Check out this link. McFeweley's is a great place to get screws,
http://www.mcfeelys.com/catalogsearch/r ... ad_size=86
PostPosted: April 9th, 2016, 4:05 pm
Tom,
Thanks! Will give the #4-3/8" a try with the square drive.
Just ordered 200. Should be enough for awhile.
PostPosted: April 9th, 2016, 7:21 pm
Received my Pocket CLIO system from PE today and set it up on my Netbook running Windows 10 64bit OS. Took the frequency response measurements for the open baffle planars using the BG NEO3PDR and NEO10 planars with the 6x12" servo subs. This is an overlay of the midrange and tweeters crossover responses.
Once I get the FPS line arrays running will see what crossover is needed with them.
PostPosted: April 10th, 2016, 6:54 am
The BG NEO3PDR planar tweeters went on sale this morning at Parts Express.
They are on order and should be here in July. Then it will be time to build the larger line arrays.
PostPosted: April 10th, 2016, 9:29 am
This months Parts Express magazine has an interesting article by Don Keele about the CBT array with beam patterns above a ground plane. I have multiple copies if anyone is interested in one.
PostPosted: April 10th, 2016, 9:50 am
Stuart is interested in one, Thank yoyouy very much!
PostPosted: April 10th, 2016, 10:22 am
Ok, PM sent.
PostPosted: April 10th, 2016, 3:53 pm
Here is a link to Don's website where you can get not only the CBT info but his other papers as well. He also received a technical Oscar for his work with horns in motion picture sound. I've known Don for years and he is not only a very knowledgeable guy but a first class person as well. He may be a judge with me at this summer's Midwest Audiofest speaker building competition.
http://www.xlrtechs.com/dbkeele.com/
Users browsing this forum: Bing [Bot] and 63 guests
