It is currently December 11th, 2025, 9:27 am
PostPosted: October 27th, 2015, 7:33 am
Have tweeters that are a bit edgy, using basic Dayton metalized PP caps. Thinking that better caps might tame them a bit. Could get by with only two, but would like 4:
PPFX
Mundorf
Auricap
Sonicap
Jensen
Jupiter
V-Cap OIMP
whatever.......
PostPosted: October 27th, 2015, 8:56 am
I have had good luck with PIO's off of ebay
The usual naysayers will be ignored
PostPosted: October 27th, 2015, 9:00 am
Which PIO caps? The Russian k40Y9 type?
PostPosted: October 27th, 2015, 9:08 am
I have gotten a few. The Russian's seem fine and reasonable. Also motor run caps have a large following
But full disclosure my personal opinion that boutique caps are bogus.
PostPosted: October 27th, 2015, 9:10 am
Thanks. Maybe I'll just use some NP Nichicons. Probably I'm imagining any differences.
Kidding! Sorry, I'm in the other camp. Sadly, I hear differences, lots of them. Bad for my wallet!
PostPosted: October 27th, 2015, 9:31 am
I hear differences also, but have decided its not worth it. I like to get rid of the stress
PostPosted: October 27th, 2015, 9:36 am
I don't blame you one little bit!!!!
Keeps lots more $$$ in your piggy bank for other projects!
More hair on your head also!
It's just that feeling of running sheetrock screws into my ears that makes me keep trying! I listen for detail, soundstage, microdynamics, etc., so revealing tweeters do it for me. Unfortunately, that's a double edged sword demanding fine components upstream!
PostPosted: October 27th, 2015, 10:57 am
I have a cache of 5-ufd/350-wvdc Electronics Concepts caps that in my experience surpass any of the so-called audio-phile caps. Their self-resonance is out beyond 250-kHz.
I can provide you with matched pairs. At 8-ohms the difference in the -3-db crossover point is only 750-Hz. (4,750-Hz -- 4-ufd vs. 4,000-Hz -- 5-ufd).
I can even sort for the lowest values within tolerance to get you closer if you like -- although I found that some overlap works best.
PostPosted: October 27th, 2015, 12:45 pm
A blast from the past. I have two 8uf 200V Wonder Caps if you are interested.
PostPosted: October 27th, 2015, 3:41 pm
I wouldn't mind auditioning a pair, if you're amenable. If I like them I'd buy them, if the price is right.....
BTW, I'm using 2nd order Butterworth filters: 4.0uF & 0.51mH for 3500, so even 4.7uF & 0.51 = moves me to 3250Hz, a little low. If there are ~4.5uF caps in the bunch, it might be better.
Thanks
