It is currently November 23rd, 2026, 11:06 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: October 11th, 2026, 6:42 pm
Chassis is done and waiting on the final AC power supply to arrive for testing and listening.
PostPosted: October 16th, 2026, 7:58 am
The new SMPS arrived and got it installed in the chassis.
Final wiring to the new XLR's is soon.
PostPosted: October 17th, 2026, 2:49 pm
Have my 2 channel XLR to RCA active converter setup with Sparkos Labs SS3601 discrete opamps.
This feeds a Douk Audio A5 Class D stereo amps with SS3602 opamps installed. The stereo amp is RCA input only.
Stock Magnepan LRS speakers for listening.
PostPosted: October 19th, 2026, 8:55 am
The 4 channel prototype is working and doing a 24 hour burn-in to check all components. This has 4 - Staccato OSH-S discrete opamps installed as monoblock amp channels with full voltage regulation per channel.
The listening session shows much improvement over the XLR to RCA adapter cable as expected
The amp is a Douk Audio A5 stereo TPA3255 Class D amp with RCA inputs. Moded it with Sparkos Labs SS3602 discrete opamps to replace the TI NE5532 ICs.
Now for some more listening! :)
PostPosted: October 25th, 2026, 4:10 pm
The active converter is working well with Douk A5, Alsozone GaN Mono and FOSI V3 Mono amps.
Got it packed today to go to a group listening session for some feedback.
PostPosted: October 28th, 2026, 2:10 pm
Next is building a two channel version of the converter.
This one is to try two Sparkos Labs SS2590 Pro single discrete opamp with the 8 pin DIP converters to use the same circuit with higher current +/-12VDC voltage regulators.
These discrete units have a max output current of 275mA Class AB and 35mA Class A bias.
PostPosted: October 29th, 2026, 7:45 am
The next version will be using Texas Components TX2575 bulk naked metal foil resistors with 0.01% tolerance and a TC of 1ppm. These are best sounding resistors I have ever worked with, but not cheap.
The opamp will be the Sparkos Labs 2590 Pro single amp discrete unit with the 8 pin adapter for easy changes. Will also have the Sparkos Labs SS3601 and Staccato OSH-S discretes to compare.
The power supply will be changed to higher current MoFi S7812 and S7912 discrete low noise regulators. Aliexpress has them with heatsinks installed as pairs.
The chassis cutting has begun and waiting on parts now will be the time question.
PostPosted: November 14th, 2026, 4:48 pm
For the next version of the XLR to RCA converter, some of the discrete opamps will need a higher current power supply.
These are bipolar power supply boards with LDO low noise voltage regulators. Good to 1.5A per module, and one module per channel. Should work nicely! :)
The LDO boards are being driven by a 30W smps.
PostPosted: November 15th, 2026, 12:16 am
Metal foil resistors also known as bulk-foil resistors such as the Vishay product or Texas product are superb in an audio critical path. Yet one "ancient" device I found goes beyond the bulk foils that serve music with supreme integrity.
They are precision non-inductive bobbin wire-wound resistors. The only way I can explain the difference is like the difference between regular television (NTSC) vs. high-def television (ATSC). One can be satisfied with bulk-film resistors until you hear what a
bobbin does in the same circuit. Standard wire-wound resistors act like tiny coils, creating unwanted inductance. Non-inductive Shallcross types typically use an Ayrton-Perry (or counter-wound) winding technique, where the resistance wire is doubled back
or wound in opposing clockwise and anti-clockwise directions. They are still manufactured by Shallcross and others, but those goodies can be found on eBay as vendors get them off auctions at the end of Government contracts.
You won't be disappointed.
The following link is a source of really superb bobbins that don't cost an "arm, leg, and your first-born male child."
https://www.ebay.com/itm/297945273560?_ ... SG48SM89E5
PostPosted: November 15th, 2026, 8:14 am
Thanks for the recommendation.
Found the RX70 spec sheet for the resistors. Sounds like the are bifalar wound to cancel inductance. Nice that they are 0.01% tolerance. They would work well in crossovers like the Mills resistors.
Their TC is 10ppm. Very good by metal film resistor specs usually around 25ppm for very good ones. That is 10x the TX2575 TC spec at 1ppm. That is what matters in feedback loops.
Since the TX2575 element is about 1/8in x 1/8in, their self inductance will the very low to start. The Vishay S102K Bulk metal foils were bigger.
Will look into them for a listening trial.
