It is currently September 19th, 2025, 5:11 am
PostPosted: March 30th, 2025, 1:25 pm
Being a user of the 845 directly-heated power-triode it is been frustrating that most if not all tube testers are not fitted with the "jumbo" tube socket.
That issue has now been eliminated with a jumbo-socket adapter that recently came on the market. Here is the link:
https://www.ebay.com/itm/355472580407
The information provided only has settings for two tube testers; however, any tube tester that has standard 4-pin sockets for the likes of 300Bs can be setup with a little fiddling.
I started with the 300B settings for pin-out then set about establishing settings for sensitivity, load, etc.
I used a known 845 as a benchmark and can now test my own 845s for viability and especially for matching pairs.
PostPosted: March 31st, 2025, 12:35 am
10 volts at 3.5A filament supply is pretty tough for any tube tester in my collection.
PostPosted: March 31st, 2025, 10:08 am
I also thought so. Yet the reality is that it is no problem. My tester fuses out at 1-amp. @ 120-vac. (120-VA)
10-volts @ 3.5-amps. is only 35-VA. My tester does not have a 10-volt setting, but the 845 works pretty well with 7.5-volts for the purpose of testing.
I was "chicken" to try the next setting of 12.5-volts on a perfectly good tube.
Anyhow I was able to test a couple of tubes with no issues. The adapter ROCKS!
:thumbup:
PostPosted: March 31st, 2025, 11:12 am
https://www.youtube.com/watch?v=4Y2fj11fzWM
PostPosted: March 31st, 2025, 11:27 am
YIKES!! That's akin to asking what time is it and having to sit through a lecture on how a watch works.
The adapter satisfies the K.I.S.S. method.
Users browsing this forum: No registered users and 281 guests
