It is currently November 8th, 2025, 5:49 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: June 4th, 2013, 12:30 pm
Grover used a 6N7 as an input tube for multiple amps, I'm sure he could provide some good info.
PostPosted: June 4th, 2013, 12:41 pm
Administrator/Moderator/Almighty one, is Grover subscribed here?
PostPosted: June 4th, 2013, 1:21 pm
Not to the best of my knowledge...
PostPosted: June 4th, 2013, 2:58 pm
Okay, here we go! Thanks, Roscoe.
Parallel 6N7 is a great tube, gain of 35, Rp around 22K I think. Very musical. Check out Thomas Mayer's blog:
http://vinylsavor.blogspot.com
He has a "Tube of the Month" feature and some of these are inexpensive high-gain tubes that have been overlooked by the hobbyists. You might find something you like there.
Last edited by Roscoe Primrose on June 4th, 2013, 3:12 pm, edited 1 time in total.
Made url clickable...
PostPosted: June 4th, 2013, 3:32 pm
Oh, as for the 6N7 as a differential amp, it's great. Again, gain of around 35. Don't know the Rp for the individual sections. There is a well-known vintage amp that used this as a differential phase splitter but I can't recall which one it was. I think you would typically use about 47K plate load per section running at bout 3 ma each.
PostPosted: June 4th, 2013, 8:47 pm
Interesting. Any idea where to find curves and Cg-p data? I only found a listing as a Class B amplifier. I may even have some. Did I mention I like octal? :D
It's the same as 6A6 and 53, electrically.
Here's a Tong-Sol data sheet for the 6A6, courtesy of Frank's Electron tube Pages:
http://tubedata.tubes.se/sheets/127/6/6A6.pdf
OK, sorry, that one's for Power Duty, not small-signal use.
Here's the set of curves we're looking for....
http://tubedata.tubes.se/sheets/021/6/6A6.pdf
PostPosted: June 5th, 2013, 3:14 am
Oh, excellent, thanks!
PostPosted: June 17th, 2013, 12:29 pm
How about a 1633 as a replacement for one of the 6SN7s? It's a special grade with tightly matched sections.
It's for military radios, so it has a 25V heater, but otherwise it's just a 6SN7 with matched sections.
Yes it's Octal.... :roll:
Yes, you can borrow a couple if you want to test them.... :clap:
http://frank.pocnet.net/sheets/049/1/1631.pdf
PostPosted: June 17th, 2013, 2:20 pm
FerdinandII,
Interesting choice - I've not heard about that one! Let me stir it into the mix and see what drops out. The heater doesn't throw me. As you say, it looks like another 6SN7/6J7 but with a difference heater requirement. It also looks like the plate ti reduced to 300V from 450V, and plate dissipation drops from 7.5W to 2.5W. Grid-to-Plate capacitance is a little lower, and you say the sections are better matched. Let's see if I can determine how much head room I have with these.
PostPosted: June 17th, 2013, 2:53 pm
Guy,
Sorry for any confusion, but I meant to recommend it to Stuart, since he's gone all DIFF AMP on me...... :lolno:
Nothing that would prevent you from using it, but NOS choice is limited and they can be pricey.
Guy wrote:
FerdinandII,
Users browsing this forum: No registered users and 143 guests
