It is currently October 24th, 2026, 5:40 pm
 Post subject: Speaker Snap
PostPosted: April 22nd, 2023, 3:39 pm
https://www.speakersnap.com/
Quote:
The Fastest Banana Plugs Money Can Buy
 Post subject: Re: Speaker Snap
PostPosted: April 22nd, 2023, 11:36 pm
Cool! Thank you! I need those! ;-)
PostPosted: April 23rd, 2023, 4:20 pm
Is it me, or does the ones with the screws look less cheap?
PostPosted: April 23rd, 2023, 8:05 pm
WRT Audio connections, low mass is usually better, even if they look cheap.
Sudden changes in "sectional density" can cause issues.
For speaker connections, these tube connectors are a good example of a smooth transition from one piece of wire to the next.
PostPosted: April 23rd, 2023, 8:20 pm
These "Wago-style" connectors have taken over the junction box wiring market.
https://www.wago.com/us/discover-wire-and-splicing-connectors/221
https://ideadigitalasset.com/DAMRoot/Original/10069/11008_ID-SPE-v1-SNAP5362WA.pdf
I won't comment on whether they are any good for that application, as I am not qualified.
In general though, most innovations designed to make a professional's job easier, faster, and more foolproof will increase the number of ways that an amateur can screw it up.
PostPosted: April 23rd, 2023, 10:01 pm
As far as I am concerned the following link will take you to just about best banana plugs money can buy. They are aggressive for a tight fit and can be soldered.
https://www.ebay.com/itm/373874884522?h ... BMoJXej_Zh
Users browsing this forum: Google [Bot] and 24 guests
