It is currently December 8th, 2025, 3:28 pm
 Post subject: Digitizing Records
PostPosted: October 10th, 2022, 10:58 am
What ADC would you recommend for digitizing vinyl?
 Post subject: Re: Digitizing Records
PostPosted: October 10th, 2022, 11:01 am
I use an Asus Xonar Essence ST sound card. Up to 24-192, sounds great, in my opinion. I have an extra if I recall correctly. They require a PCI slot. I can demonstrate the results.
PostPosted: October 10th, 2022, 11:03 am
Thank you. I have a Xonar Essence STX II which I can use.
PostPosted: October 10th, 2022, 11:04 am
Have you tried it? I expect the results would be the same.
PostPosted: October 10th, 2022, 11:44 am
Will try it soon.
PostPosted: October 10th, 2022, 12:51 pm
If you want a stand alone unit with a USB connection youy might want to look at the Focusrite Scarlett 2i2. I use it when doing measurements using the ARTA suite but it is a very high quality ADC and DAC in one unit.
https://www.amazon.com/Focusrite-Scarle ... 10ad0&th=1
