It is currently October 7th, 2026, 1:20 am
 Post subject: Re: Best practices
PostPosted: April 12th, 2022, 5:05 pm
I used these boards from PartsExpress for the passive crossovers for the "eggs".
https://www.parts-express.com/White-Per ... -7-260-190
PostPosted: April 12th, 2022, 5:14 pm
When I am working with any board material that has holes, I insert the component leads through the holes and then wrap them with the appropriate sized buss wire. Here are photos of the top and bottom of the "Cherry Bomb" amp where you can see that technique. The wire layout is similar to what you would have with a PC board, but is much more flexible than a PC board.
PostPosted: April 12th, 2022, 5:23 pm
If I were doing crossover boards where I expected to make changes, I would use Waygo connectors.
https://www.wago.com/au/electrical-interconnections/discover-installation-terminal-blocks-and-connectors/221
I use Goop to attach them securely to a board and simply insert the wires. I find them really useful for creating a ground bus and other arrangements where multiple wires come together and I expect to make changes. To make a change, simply flip the appropriate lever and remove the wire to the component and replace with the wire to the different component.
PostPosted: April 12th, 2022, 5:28 pm
Kind of hard to do with 14ga solid wire
PostPosted: April 12th, 2022, 5:39 pm
They handle 10 - 26 awg, both stranded and solid.
Users browsing this forum: No registered users and 145 guests
