It is currently August 31st, 2025, 4:55 am
PostPosted: October 11th, 2021, 5:06 pm
As I understand it, a DC current can cause molecules of the filament metal to migrate over time. It is similar to a plating process where metal molecules move to a charged metal plate. Different process but a similar result. It causes thinning in part of the filament which then has greater dissipation and earlier failure.
I dont think molecules move/migrate in solid metal. Only the valance electrons drift in the direction opposite to current.
PostPosted: October 11th, 2021, 5:11 pm
https://www.synopsys.com/glossary/what-is-electromigration.html#:~:text=Electromigration%20is%20the%20movement%20of,vacancies'%20and%20'deposits'.
Atoms.
PostPosted: October 11th, 2021, 5:29 pm
ratbagp wrote:
Atoms don’t move either. Atoms get excited under heat or pressure but they don’t move. Only the valance elections drift between the atoms. At that what I learned in school.
PostPosted: October 11th, 2021, 6:11 pm
Not true. That is what happens with regular current flow but electromigration is different. The actual atoms move.
PostPosted: October 11th, 2021, 6:34 pm
OK, I get that no one has tried Ronan Regulators for DHT heating. I will leave you all to debate how many angels on a pin.
PostPosted: October 11th, 2021, 7:19 pm
The best I can do for a "Like" button..... :handgestures-thumbupleft:
or maybe? :text-+1:
PostPosted: October 11th, 2021, 7:41 pm
13, all male.
BTW, what are male angels called?
PostPosted: October 11th, 2021, 8:05 pm
Ok, my bad. Thought we are talking about current flow.
