It is currently December 15th, 2025, 2:23 am
 Post subject: Re: Digital Music Server
PostPosted: May 10th, 2021, 11:56 am
HQPlayer is included in GentooPlayer.
The HQPlayer renderer component (Network Audio Daemon) is included in gentooplayer. HQPlayer itself costs $260.
PostPosted: May 10th, 2021, 12:30 pm
DaveR wrote:
I was showing that there isn't a lot of horse power needed for upsampling, at least for PCM.
My PC was able resample all PCM sources, even 24bit/192Khz, without an issue. It was also able to handle DSD64 sources. However, on DSD128 sources, it choked.
Perhaps it's the software that's causing the problem.
PostPosted: May 10th, 2021, 1:28 pm
Depending on where the files are being pulled from and/or sent to, it could also be an ethernet issue.
PostPosted: May 10th, 2021, 1:43 pm
PCM->DSD conversion is more computationally intensive. When I tried using Roon's DSP capabilities, upsampling PCM to 176kHz/24bit from 44kHz/16bit only loaded up my NUC7i5 a few percent. However converting to DSD128 loaded up the CPU considerably.
PostPosted: May 10th, 2021, 2:02 pm
Not at all. I was able to play DSD512 without any issues. With the resampler plugin enabled, CPU core saturation occurs or DSD128 and higher.
PostPosted: May 10th, 2021, 2:14 pm
What's the point of converting PCM to DSD?
PostPosted: May 10th, 2021, 2:37 pm
C'mon Dave, some folks think it sounds better in their system. It's a hobby. :-)
PostPosted: May 10th, 2021, 3:31 pm
For some, the point would be to bypass all the filters and resampling built into your DAC.
PostPosted: May 10th, 2021, 3:36 pm
Sending DSD to your DAC may result in different filters being applied, but you're not going to have none....
PostPosted: May 10th, 2021, 3:39 pm
Grover, et. al.,
Yes, particularly if the DAC accepts a DSD stream natively, you can then process PCM using better conversion method than what is built into silicon.
