It is currently October 16th, 2025, 2:55 pm
PostPosted: April 29th, 2021, 3:26 pm
I went to the trouble of calibrating my mic to TrueRTA in SPL mode. Not the most accurate SPL meter (original RatShack) but close enough.
RTA generating 1kHz and SPL set based on what the RatShack said in db's.
any way first I noticed the background noise with TrueRTA in measure mode SPL and most of the noise was in the 10-30Hz at 40db down. the noise diminished from there as the freq went up
Does this seem typical or normal?
I know it is not affecting listening in the +80db range
PostPosted: April 29th, 2021, 3:55 pm
Paul,
I think a level of 40 dB is pretty typical household noise level according to a chart I searched for:
https://www.uofmhealth.org/health-library/tf4173
Another chart, focused on sources:
https://chchearing.org/noise/common-env ... se-levels/
10 to 30 Hz is pretty low frequency, could be traffic noise, rumbling from trains, etc.
Hope this helps.
PostPosted: April 29th, 2021, 3:59 pm
Paul,
Found this really interesting:
https://www.archtoolbox.com/materials-s ... evels.html
PostPosted: April 29th, 2021, 4:09 pm
Thanks David
I should have search but maybe not a waste of time for the members
at least I know my equipment is in the normal range
PostPosted: April 29th, 2021, 4:14 pm
Paul,
No problem. It gave me an opportunity to learn something, as well as anyone else who checked out the links. For instance, the limit of audibility of LF noise is much higher than I expected it to be.
PostPosted: April 29th, 2021, 4:24 pm
I have been trying to get rid of a 100hz bump in the Razz speakers. The designer likes this bump. He calls it the "Fun" part.
it was only a few db's and by moving the speakers around I have reduced it by half. The fun part for me is to watch this on the
real-time analyzer. It took just moving the speakers out into the room about 6 inches.
My first try was to partially block the port with open cell foam. That helped but now with the change in position it now sounds better without the block.
PostPosted: April 29th, 2021, 4:26 pm
this is before I moved the speakers
I didn't keep the graph of after the move.
but you can see there is too much lo bass and its a bit boomy
PostPosted: April 29th, 2021, 4:35 pm
Paul,
100Hz has a wavelength of 11 feet, so if you are 2.75 ft (1/4 wavelength) from a boundary (like the back wall), that should cancel out at the speaker. Of course considering all the room reflection modes and standing wave resonances, it is much more complex that this. So positioning can have a pretty big impact on low frequencies.
PostPosted: April 29th, 2021, 4:46 pm
You have to ask yourself what household equipment was running? Hermetic compressors in refrigerators have isolation but only for the mid-range frequencies. Same goes for HVAC.
If you take A-weighted measurements that "noise" may not even show up.
PostPosted: April 29th, 2021, 5:47 pm
Just for grins I set up my ACO Pacific mic in my new audio room and measured the background noise. If my calculations are correct it is 29.5 dB. My mic has a sensitivity of 16.8mV/Pa and I had to set the preamp for a gain of 20 dB to register around 1 MV on my AC voltmeter. That is a voltage gain of 10. It bounced around so it is not a precise measurement. This is broad band measurements since I used no filters. The math says that if 16.8mv is 1 Pa which is 94 dB, then 100 microvolts is about 64.5 dB down so 94 minus 64.5 equals 29.5. Can anyone tell me if I am smoking green stuff in my assessment?
Users browsing this forum: No registered users and 265 guests
