It is currently November 20th, 2026, 6:46 am
Post new topic Reply to topic  [ 131 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 14  Next
PostPosted: July 16th, 2020, 5:29 am
Is the installer booting off the USB stick? The typically installer will boot up a linux system off the USB stick and provide an option to install on the harddrive. If that did not happen, then you have an installer problem. Did you make a bootable image on the USB stick per directions. It will not work if you just copy the iso file onto the USB stick.
PostPosted: July 16th, 2020, 5:39 am
One other thing, did you set your computer bios to allow booting off a USB stick. This is pretty basic, but do not know specifically the problem you are having.
PostPosted: July 16th, 2020, 8:18 am
Or you could be crazy like me and build you own PC -
PostPosted: July 16th, 2020, 8:50 am
Or in contrast, pick up a 4 or 8GB Raspberry Pi 4, a little M.4 PCIe SSD card in a USB 3 case, slap them on the back of a monitor, hook up a wireless keyboard and mouse, and call it a day. Nice little Linux system for next to nothing.
PostPosted: July 16th, 2020, 10:32 am
Don't forget the Intel NUC. Lots of good choices.
PostPosted: July 16th, 2020, 11:14 am
I have a couple of NUCs, wonderful little powerhouse of a box. I set my wife up with one over Christmas, and she loves that it fully replaced her big honking desktop (that I built for her ages ago). I liked it so much, I bought one for me for my basement system. It is a bit more $ than a RPI 4, though.
PostPosted: July 16th, 2020, 11:21 am
Perfect platform for Daphile.
PostPosted: July 16th, 2020, 11:37 am
I ran a converted Chromebox for Daphile for some time in the main system. Pretty nice, but underpowered (due to the Chromebox) AND I wanted to get the server element out of my rack. Moved on to an minimalist approach using a RPi 4 renderer running PiCorePlayer networked to a remotely located Synology NAS running LMS 8.0. Does a pretty nice job feeding my Chord Qutest. But I should try Daphile on the NUC at some point, it is a far more powerful box and can do software upsampling more effectively.
PostPosted: July 16th, 2020, 11:45 am
Get the beta 20.x series rather than the 19.x stable. http://www.daphile.com/firmware/beta/
PostPosted: July 16th, 2020, 11:48 am
mix4fix wrote:
Unable to load Linux. Tried two different USB boot-able programs and different versions of Linux but unable to get it to work.
Use: https://www.balena.io/etcher/ or: https://rufus.ie/ to write the iso to the USB drive..
