It is currently December 8th, 2025, 5:33 pm
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
 Post subject: Re: Klipsch Forte iii
PostPosted: July 13th, 2020, 8:02 pm
If you want these speakers to go down only to 80Hz, Forte lll’s 12” woofer with 15” passive radiator is an overkill . A 6” woofer would suffice.
Something like this:
20-80Hz. - Subwoofer
80-800Hz - 6” woofer in a sealed box. 2 woofers if you need to increase the efficiency.
800-4000Hz - JBL 2440 with Emilar Eh-800 exponential horns
> 4000 - Altec 802-8D with Faital Pro 1.4kHz elliptical tractrix horn
BTW, compression drivers listed above are vintage.
PostPosted: July 13th, 2020, 10:58 pm
If you limit yourself to what is available on Parts Express what would you use?
I was thinking of the following -
B&C ME75 2" Horn (I don't know what driver would be best)
Eminence APT 200 Super Tweeter
Scanspeak M22WSR-45 8" Woofter
PostPosted: July 14th, 2020, 11:59 am
Scanspeak M22WSR-45 frequency response until 900Hz is very flat. May be Tomp can shed some light on the specs. I wonder what type of magnet it uses.
I cant be much help regarding new compression drivers, havent tried them.
