It is currently January 26th, 2026, 3:22 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Speaker wires
PostPosted: June 2nd, 2020, 5:15 pm
I use two runs per speaker.
PostPosted: June 2nd, 2020, 5:21 pm
Thanks.
PostPosted: June 2nd, 2020, 5:59 pm
What is the preferred method of connection
Spades, banana, twist wire and wrap around terminal
Solder directlt to voice coil?
PostPosted: June 2nd, 2020, 6:11 pm
Oops I forgot
speakon connector. I am trying to find a drawing of the actual connection. How’s much area compared to spad or banana
PostPosted: June 2nd, 2020, 6:29 pm
Here is the data sheet on a 4 pole Speakon cable connector. Check out the current rating. They also have it in a version with screw clamping mechanism instead of solder terminals.
nlt4fx-bag.pdf [89.63 KiB]
Downloaded 790 times
PostPosted: June 2nd, 2020, 7:25 pm
Have been using the 4 pole Speakon connectors for the servo subs and they work very well.
Just make sure you get a good click on twist to lock the connectors when inserting them.
PostPosted: June 2nd, 2020, 9:54 pm
Gold over brass 2mohm contact resistance this seems good but it’s only good for 5000 matings that means it will only last a couple months with a geek
PostPosted: June 2nd, 2020, 10:08 pm
It's silver over brass. AG is silver, AU is gold.
PostPosted: June 3rd, 2020, 7:37 am
I use the silver plated. I have had zero issues. If your binding posts accommodate the diameter of the eight wires twisted together you don't need a termination. Fewer joints are better. Just keep in mind that copper is relatively soft so you should check the tightness of the binding post from time to time. Gently, of course.
PostPosted: June 3rd, 2020, 8:55 am
That is why you should never tin wires before clamping them down. Solder is softer than the copper and more creep will happen.
Users browsing this forum: No registered users and 53 guests
