It is currently December 6th, 2025, 3:45 pm
PostPosted: May 24th, 2020, 10:21 am
Synergistic Research does sell tiny cups as Paul described. I think Kemper has some.
PostPosted: May 24th, 2020, 11:29 am
Just for grins I put together the following:
Approximate Wavelength of Audio Frequencies in Air:
20,000-Hz. approx. = 5/8-inch
15,000-Hz. approx. = 1-inch
10,000-Hz. approx. = 1-3/8-inch
8,000-Hz. approx. = 1-11/16-inch
5,000-Hz. approx. = 2-11/16-inches
3,000-Hz. approx. = 4-1/2-inches
2,000-Hz. approx. = 6-3/4-inches (1/2-foot)
800-Hz. approx. = 16-7/8-inches (1-1/3-foot)
400-Hz. approx. = 33-3/4-inches (2-3/4-feet)
100-Hz. approx. = 135-inches (11-1/4-feet)
50-Hz. approx. = 270-inches (22-1/2-feet)
30-Hz. approx. = 450-inches (37-1/2-feet)
20-Hz. approx. = 675-inches (56-1/4-feet)
Or - to put it perspective - we strive to eliminate unwanted resonances and distortions in our quest for good sound reproduction - why on earth would we even consider such device such as resonating bells and hollow metal cups?! :confusion-confused: I'm cornfused.
PostPosted: May 24th, 2020, 11:51 am
Walt,
What are you driving at by posting the wavelength chart?
Resonance frequency is not dependent upon the diameter of the resonating medium being equal to the wavelength. You don’t need 56’ drum to generate 20Hz sound wave.
PostPosted: May 24th, 2020, 11:57 am
Walt,
Resonance frequency is not on the diameter of the resonating medium. You don’t need 56’ drum to generate 20Hz sound wave.
If anyone can find out what frequency these gizmos resonant at they'll have an idea what effect they can have on the sound. As I said, we strive to eliminate unwanted resonances and distortions in our quest for good sound reproduction - why on earth would we even consider such device such as resonating bells and hollow metal cups?! :confusion-confused: I'm cornfused.
PostPosted: May 24th, 2020, 12:45 pm
Walt,
Helmholtz resonators can be used to tame peaks in sub-bass frequencies.
PostPosted: May 24th, 2020, 2:05 pm
Talk to Paul McGowen about Hemhilts Resonators on how uneffective they were when he built his first sound room for his RS-whatevers
PostPosted: May 24th, 2020, 6:40 pm
Came across this video.
https://youtu.be/Ck-fZJvf39M
Paul is using huge Helmholtz resonator to dissipate bass energy. My goal is to use the phase reversed energy yo cancel some of the energy at peaks, about 8-10dB. Small portable resonators will get the job done.
PostPosted: May 24th, 2020, 6:46 pm
Good luck
 Post subject: Portable Resonators
PostPosted: May 25th, 2020, 9:04 am
http://www.acusticaapplicata.com/polifemo.php?lang=eng
PostPosted: May 25th, 2020, 10:07 am
whatever floats your boat... man
Get a sonotube and mount an old woofer
