It is currently October 22nd, 2026, 9:58 pm
 Post subject: Analog multi-meter
PostPosted: March 16th, 2020, 12:53 am
Tom gave me an old analog multi-meter. One thing I noticed was the lead connections look like banana plugs. I thought the leads on modern DMM (Fluke) was standard for every kind?
Put batteries in it (9V and AA) and tested it on ohms and VAC.
 Post subject: Re: Analog multi-meter
PostPosted: March 16th, 2020, 9:30 am
That meter is probably 30 years old so who knows what was used back then. I also have some older test equipment that has AC input sockets that are not used anymore. If the cords fail I will have to replace the input sockets with IEC sockets. Time marches on.
PostPosted: March 16th, 2020, 9:33 am
PLUS -- it was FREE!!! In the realm of DIY you adapt -- you create -- you make it happen.
PostPosted: March 16th, 2020, 10:21 am
A 30 year old multimeter is before any safety standards/considerations to guard the male jack to prevent shock when inserting or removing leads. It is pretty typical for older multimeters and other test equipment to have a simple banana plugs or 3-way binding posts with banana plug leads.
Should be easy to find a pair of leads on Amazon.
PostPosted: March 16th, 2020, 12:57 pm
The original leads were with it.
PostPosted: March 16th, 2020, 1:32 pm
I expect that the multi-meter had pin jacks. Leads for those aren't easy to find but there is at least one listing on eBay.
https://www.ebay.com/itm/HERMAN-H-SMITH ... SwsvZdMySW
PostPosted: March 16th, 2020, 3:01 pm
those are no good they are not free
PostPosted: March 16th, 2020, 3:04 pm
OH! My bad! :twisted:
PostPosted: March 17th, 2020, 8:53 am
Candidate for the "Best Post of 2020"!
Users browsing this forum: No registered users and 124 guests
