It is currently September 8th, 2026, 9:54 pm
PostPosted: November 8th, 2019, 4:08 pm
What's worse: an old DAC or a built in DAC in the average cheap DVD/CD player? Would that old DAC improve the player's sound?
PostPosted: November 8th, 2019, 4:30 pm
You’d need to look at it on a case by case basis, but generally speaking a good old dac is probably better than a cheap new player...
PostPosted: November 11th, 2019, 12:38 am
It's that Pop Pulse that has the left channel issue when connected to optical. I hooked it to a old Sony DVD player and use it to listen to CDs.
PostPosted: December 29th, 2019, 2:53 pm
How about the built-in DAC on the average AV receiver?
PostPosted: December 29th, 2019, 3:55 pm
I bet they measure quite well.
PostPosted: December 29th, 2019, 4:34 pm
There's no one answer for every possible combination of products. Try it both ways and see which sounds better. It's fun!
PostPosted: December 29th, 2019, 7:46 pm
You could try just listening to music instead of monkeying around with junk equipment
