For more information, see the following link (among others):
http://www.pimmlabs.com/web/Active_load ... ntrol.htmlSome experimenters have experienced high-frequency oscillation in CCSs because of pickup of external radio frequencies (RF). Oscillation can be controlled by adding a small-valued resistor (R2-R9) in series with the gate of each MOSFET to filter the RF. Some experimenters jumper the gate-stopper resistors (R2-R9) and have no oscillations; those who experience oscillation use the smallest resistor they can to stop the oscillations – some use just 100 Ohms instead of the specified 1000 Ohms. The choice is up to the builder.
Adjustment-Resistor Values can be estimated with this equation:
Adjustment Resistor in Ohms =1585.43 × (current in mA) ^ −1.08225 (i.e., desired current to the power of -1.08)
Current Output can be estimated with this equation:
Output Current in mA = 904.242 × (Resistor Value in Ohms) ^ −0.9237 (i.e., resistance to the power of -0.92)
The specified trimmers are for currents greater than about 1½ mA. For more adjustment of higher currents, the builder may want to substitute a lower-value trimmer resistor for U1-U4. For example, a 250-Ohm trimmer is probably good for currents over 6 mA, and a 100-Ohm trimmer is probably good for currents over 13 mA.
There are provisions on the PCB to replace the current-adjust resistors (U1-U4) with fixed resistors like those used for (R2-R9) once the required values are found by experiment. The builder may want to buy a single adjustable resistor to find the required value, and then buy cheaper fixed resistors for the CCSs.
Populating the Board:Start by installing the TO 92 packages (M8, M6, M4, M2). The center lead must be bent away from the flat side and down to meet the center pads on the board for each part. Installing the TO 92 packages first allows better access for heat-sinking the leads while soldering.
Next, install the TO 220 packages. The leads can be left straight if the heat sink is mounted perpendicular to the PCB. If the heat sink is below and parallel to the PCB, bend the leads up as shown in the earlier figure called "TO-220 Under." If the heat sink is above and parallel to the PCB, or about on the same plane as the PCB, bend the leads down as shown in the earlier figure called "TO-220 Over." Provide proper heat sinking to leads while soldering.
Install the CERMET pots (U4-U1), followed by the grid-stopper resistors (R9-R2). If fixed current-adjust resistors are used, replace the pot with a fixed resistor. For example, Figure 7 shows the leftmost adjustable resistor U4 replaced by a fixed resistor. The other three CCSs have similar pads for fixed resistors.
File comment: Replacing a TrimPot with a Fixed Resistor
Adjusting the CircuitAn easy way to set the current is to connect a 1KΩ resistor from one of the outputs (O1 O4) to ground, and a power source from the appropriate input (IN1, IN2) to ground as shown in the figure below. Apply at least 20V DC to the current source and adjust the appropriate current-adjust resistor to the desired current output. Measure the voltage across the load resistor (Rload). Compute the output current, which is the measured load voltage divided by the load resistance (1,000 Ohms). For example, to adjust for 30 mA, there will be 30 Volts across the load resistor and at least 20 Volts across the current source, so a minimum of 50 Volts DC is required from the power source. Other values of load resistors can be used to allow other voltages for setting the output current - just use the value of the load resistor in the equation.
File comment: Circuit to Find Current-Adjust Resistor
