It is currently October 18th, 2025, 4:46 am
PostPosted: August 18th, 2019, 5:32 pm
The Khadas is in and housed. I drive my main amp plus a pair of subwoofers so I wanted two outputs without having to use Y cables. I ended up mounting the DAC on some perf board cut to slide in on the lowest grooves in the enclosure.
I removed the three RCA connectors that came on the board and put four new ones on one of the panels. Mounting the Khadas to the perf board proved to be more challenging than I thought. I have a lot of hardware, it's mostly even sorted, but I didn't have enough #2 or 2.5mm to pull it off. I ended up using the hardware that came with the card and two washers under each of the screws to stand the DAC off the perf board.
This is one side with the USB-C connector poking through.
And here's the other side
I should have put another RCA on the other side for SPDIF, but I don't really use it so I didn't think of it. It will be easy to add later. If you use this enclosure note that the screws are #1 pozi-drive. It will be much easier to get them seated if you use the correct bit.
First impressions of the sound are excellent. I've spent more time getting it in the box than listening to it. More listening is in order.
PostPosted: August 19th, 2019, 8:23 am
What does the power supply look like? Seems like it must be USB bus powered. If that is the case, and you like the DAC sufficiently, then a split USB cable and separate linear 5VDC supply may yield another significant improvement.
Last edited by Stuart Polansky on August 19th, 2019, 11:08 am, edited 2 times in total.
PostPosted: August 19th, 2019, 8:28 am
Power is via USB. Since any noise on the power supply is common mode it should not affect the sound. I know this is contrary to the general opinion around these parts.
PostPosted: August 19th, 2019, 10:43 am
I’m planning on trying the Khadas, but would like the option to use Toslink from a Chromecast Audio (in addition to coax and usb). Does anyone have experience with any Toslink to coax converters? I see them listed inexpensively on eBay and Amazon, but I don’t know if they are any good, haven’t found other other options.
Thanks in advance.
PostPosted: August 19th, 2019, 11:12 am
With prices in the $13 to $16 price range I would go for it. I think the biggest limitation is Toslink itself.
PostPosted: August 19th, 2019, 11:14 am
Thanks in advance.
Toslink from day one was designed to provide an inexpensive way to transmit digital for home theater systems. Ordinary 75-ohm coax will outperform Toslink any day of the week. If you shop for 75-ohm coax designed for high resolution television production those are by far superior to the cables "designed" for audio.
You can window shop here: https://www.markertek.com/
I have had direct experience with Toslink, ST-optical, SP/DIF coax, and AES/EBU balanced line. You can trust that Toslink does not compare on any level with those other choices.
PostPosted: August 19th, 2019, 11:24 am
Thanks in advance.
Thank you for the reply. Unfortunately, the little Chromecast Audio device, which is pretty useful, only outputs analog or Toslink; hence my inquiry. I will also use coax and usb on the Khadas, but would like to give it a try with the Chromecast Audio as well.
Thanks to the link you provided I found a much higher quality-looking item than what I had previously seen. https://www.markertek.com/product/gtv-d ... -converter
Thanks again,
Pete
PostPosted: August 19th, 2019, 11:28 am
Yes, that's what I was thinking. Online reviews suggest it's in the nature of a disposable item. And as you and Walt point out, Toslink is the issue. Now I just have to decide if I want to be a cheapskate, or go for the more solid looking Gefen item I found on Markertek.
Thanks for the help,
Pete
PostPosted: August 19th, 2019, 11:34 am
Pete
Me thinks you need to decide if you are only looking for basic sound reproduction (for background) or if you want to sit and really enjoy music the best way possible.
I grant that for most of us cost is an object, but double-digit $$ does not even come close to the point of diminishing returns.
BTW -- TOSLINK is short for Toshiba Link.
PostPosted: August 19th, 2019, 11:55 am
Pete
Yes, the Chromecast Audio is convenient for casual streaming sources, and I'll hook up a good CD player/transport and a computer for better quality options.
Now you're causing me to look up the Toshiba link (pun!) to optical audio - down the Google rabbit hole!
Thanks again,
Pete
Users browsing this forum: No registered users and 308 guests
