It is currently October 22nd, 2025, 3:04 pm
 Post subject: Hegeman and Morrison
PostPosted: May 30th, 2019, 12:02 pm
Has anyone in the group tried to build Hegeman or Morrison type speakers -
http://www.roger-russell.com/omni/omni.htm#onea
https://www.morrisonaudio.com/
My math teacher in college has a system with Hegeman speakers, Mac Intosh integrated amp, AR turntable, and a Weathers cartridge. Back then (1968) it sure sounded good to me.
 Post subject: Re: Hegeman and Morrison
PostPosted: May 30th, 2019, 12:39 pm
http://www.larsenhifi.com/en/index.htm
https://www.youtube.com/watch?v=mOkCiw2015U
This is a brand that has been at CAF for a recent few years.
PostPosted: May 30th, 2019, 1:27 pm
https://ohmspeaker.com/speakers/
Still kicking...
PostPosted: May 30th, 2019, 2:13 pm
Are there any links where you can see the tweeters on the modern Ohm speakers. The Larsen speakers are not really omni's are they? Has any member tried to build a speaker like the Hegeman or Morrison?
PostPosted: May 30th, 2019, 2:18 pm
https://ohmspeaker.com/technology/#3-d-stereo-imaging
PostPosted: May 30th, 2019, 2:27 pm
From the picture it does not look like the ohm high frequency driver is omnidirectional. Aside from the link you sent me there seems to be very little information online about it.
PostPosted: May 30th, 2019, 2:42 pm
It looks like Hegeman used old cigarette butts as damping material and glued them on his woofer cones in one those pictures? :wtf: :D
I got a set of 1/4 wave tuned pipe speakers that have a single "full range" driver firing up at the top. It uses a clear plexiglass baffle over the driver to "aim" higher freq out towards the listener. It actually sounds pleasant. Sort of a point omni source except I should probably replace the flat baffle with a ping ping ball or something? These were placed in the waiting room of my wife's office and connected to a PeachTree integrated, system is used for background music.
I would think this type speaker would make greater demands on room design and placement (like corner horns)?
PostPosted: May 30th, 2019, 2:51 pm
I think you are correct- it appears limiting omni high frequencies is intentional. https://ohmspeaker.com/technology/#cohe ... rce-driver
PostPosted: May 30th, 2019, 3:03 pm
If anyone ever wanted to try the Morrison design there are a lot of different stainless steel balls available on amazon -
https://www.amazon.com/s?k=stainless+st ... _sb_noss_1
https://www.amazon.com/s?k=hollow+steel ... _sb_noss_1
The questions would be what size ball, how high above the tweeter should it be mounted, and what tweeter (midrange) to use?
PostPosted: May 30th, 2019, 3:06 pm
Unfortunately, that's probably something you'd have to figure out by trial and error...
Users browsing this forum: No registered users and 60 guests
