It is currently September 24th, 2026, 1:34 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: naked OB speaker
PostPosted: May 29th, 2019, 4:17 pm
mix4fix wrote:
That's not going to work.
WRONG!
Try it for yourself if you don't think so
PostPosted: May 29th, 2019, 4:22 pm
How about something like the Hegeman omnidirectional tweeters -
https://www.pinterest.com/pin/339740365629305645/
PostPosted: May 29th, 2019, 4:48 pm
Why would we have tweeters or mid-ranges facing toward each other? Slot loaded mids and highs?
PostPosted: May 29th, 2019, 5:22 pm
Omnidirectional output. You may like it, maybe not.
Limits vertical dispersion, but should result in faster transients.
PostPosted: May 29th, 2019, 5:37 pm
I see the Chinese are planning to restrict the export of rare earth minerals so I went ahead and purchased two of the PRV's and 4 of the GRS woofers. It should be a fun project. If it doesn't work, I can reuse them in other projects.
https://www.theguardian.com/business/2019/may/29/global-markets-fall-as-china-prepares-to-hit-back-at-us-in-trade-war
PostPosted: May 30th, 2019, 3:05 pm
ratbagp wrote:
These: https://www.parts-express.com/faitalpro ... --294-1121 or these: https://www.parts-express.com/faitalpro ... --294-1122 (if you want two per side) have a much flatter specified frequency response up high....
I've got two pairs of the discontinued Dayton Audio 15" IB drivers www.daytonaudio.com/media/resources/295-455s.pdf in the garage, might make an easy to build pair with any of the 8" full-range drivers I already have...
PostPosted: May 30th, 2019, 3:22 pm
The UK bloke with the original idea liked the 95 db aspect which is what also attracts me. The Failtalpros are 91. Perhaps not a big difference but enough. Thanks for the idea though.
Yes, I suspect the Dayton 15" would work well. You should have a go.
Currently, I am pondering how to attach the woofers together and suspend them. Bungee cords anyone?
PostPosted: May 30th, 2019, 3:42 pm
Two of the 16ohm Faitals would get you to 94dB/w/m. And for slightly less $.
Fasten them together with bolts an short lengths of steel or copper tubing. I like the look of the cradle design he had where the magnets sat in curves in the wood, but that would mean a new set of cradles for every woofer you might want to experiment with...
PostPosted: May 30th, 2019, 3:51 pm
Magnets just sitting in curved pieces of wood might lead to audible vibration problems between the magnets and the wood.
1/4" or smaller rope. Suspend from holes in the frames, with excess rope outside the frame.
Hold in place with u-bolt clamps on the rope ends. Put thick rubber plumbing-type washers between the u-bolts and frames.
Less vibration transmitted.
Adjust rope length for different drivers.
Users browsing this forum: No registered users and 102 guests
