It is currently September 21st, 2026, 12:54 am
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: Re: Daphile software
PostPosted: May 19th, 2019, 7:14 pm
mix4fix wrote:
I have two drives in the PC. No matter what drive I reload the software, it gives me a "boot media failure" after a reboot.
BIOS is pointing to a non bootable drive. Take pics of boot option screens in Bios. Most likely there will 2 screens, boot devices and boot priority.
PostPosted: May 25th, 2019, 4:41 am
I got it working.
PostPosted: November 23rd, 2019, 3:21 pm
Trying to connect it up to work, How do you get the audio to work?
PostPosted: November 24th, 2019, 6:18 pm
Audio works. Has tons of online radio stations.
PostPosted: January 26th, 2020, 2:29 am
Experimented with connecting it to an extra wireless router so I can connect with a tablet.
I am using a 7 inch tablet. When I open the page, it doesn't appear normal sized as Roscoe's does. Everything is oversized. How do you reduce the image to be smaller?
I have a 10 inch tablet I could use as well.
PostPosted: January 26th, 2020, 11:28 am
Daphile is weird that way... Try it different browser, it may be better, if may not.
PostPosted: January 26th, 2020, 11:54 am
I'm using Microsoft Edge that came on my tablet to access Daphile. Everything is stripped down on the tablet to basically only use the browser. I have Edge set up with a default page at start up that is the link to Daphile. Works fine. Screen image works.
PostPosted: January 26th, 2020, 4:31 pm
What did you do to strip down the tablet, uninstall all the apps?
PostPosted: January 26th, 2020, 4:37 pm
I did not do anything to it. I still want to use it as a tablet.
PostPosted: January 26th, 2020, 4:50 pm
While going through the initial setup of Windows I answered no to virtually every question concerning apps it wanted to activate. I also removed some stuff but I don't remember the specifics.
