It is currently August 26th, 2025, 10:55 am
 Post subject: Re: LM1875 Chip Amps...
PostPosted: November 11th, 2016, 10:04 pm
The guy between you and Sam in this picture?
PostPosted: November 12th, 2016, 10:24 am
yes
PostPosted: January 30th, 2019, 1:51 pm
I was wondering if you were intending IC amps vs Class D, etc as you mentioned class D as being something different. Class AB SS amps, whether integrated or discreet, all have some similar characteristics. When it comes to their PCB Assembly, there also they have almost similar components. And, yes, I suppose that class D amps are a bit different in that regard, yet also share a lot of the same benefits. I have some favorite class AB designs, but most are really operated in class A at reasonable levels. I also like a few class D amps, and more in some applications than others.
Last edited by AudyIltis on December 8th, 2021, 12:09 pm, edited 2 times in total.
PostPosted: November 27th, 2021, 11:26 am
Did I loan these to someone? Haven't seen them in years.... Actually have a use for them in the office system in FL.
PostPosted: November 27th, 2021, 12:24 pm
I never borrowed them or built similar, a project that went to La La land
PostPosted: November 27th, 2021, 1:27 pm
I can't even begin to count the number of my projects that ended up there....
PostPosted: November 28th, 2021, 9:45 am
Best sounding one I tried....
You hear what I hear -- I tried the LM3886 with an open-baffle Altec 604-8C, and the LM1875 based amp I later used was definitely more "musical" with that speaker.
-- Charles
Ralph Waldo Emerson
PostPosted: November 28th, 2021, 10:18 am
I remember hearing those little amps ar Roscoe’s and they sounded very good. That is why I wanted to build a set as a back up amp.
