It is currently November 3rd, 2026, 6:55 am
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: October 11th, 2018, 12:49 pm
Downloaded it. I try to save it as Flak OR mP3, and it is asking for a "command line encoder"
Do I have to download encoders?
PostPosted: October 12th, 2018, 12:27 pm
Tried Foobar and Exact Audio Copy. Can't seem to save as Flak.
PostPosted: October 12th, 2018, 12:56 pm
Make your life easy. Here are the formats dB Poweramp supports without any hassles.
PostPosted: October 12th, 2018, 2:04 pm
Search "Exact Audio Copy" on Google. You will see YouTube videos on how to Rip CDs to FLAC using Exact Audio Copy.
Remember, FLAC has different compression levels. Higher the compression, smaller the file size but the CPU has to work harder decompressing it. If storage space is not an issue, go with low compression.
EAC comes with several engines to download metadata. There is no one engine that works on all albums. Try each engine and choose the best for each album.
PostPosted: October 23rd, 2018, 6:02 pm
On a side project, can you install Daphile on an older PC?
PostPosted: October 23rd, 2018, 8:47 pm
Probably, but you may need to download the 32bit ISO depending on the old pc...
PostPosted: October 24th, 2018, 2:03 am
I know, I can't get the USB to load.
It's an old Asus motherboard with IDE drives and DDR1 memory.
PostPosted: May 18th, 2019, 8:41 pm
Using the PC that Tom gave me, I installed a couple of drives, loaded Daphile, and started loading music. Now, I can't access this PC directly (disk mount fails - no such file or directory). I can access it via network and I am rescuing all the music.
Has Daphile crashed?
PostPosted: May 19th, 2019, 8:23 am
Roscoe is the expert. He helped me build that server.
PostPosted: May 19th, 2019, 4:29 pm
I have two drives in the PC. No matter what drive I reload the software, it gives me a "boot media failure" after a reboot.
Users browsing this forum: No registered users and 148 guests
