Free Homemade Amp
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=7&t=670
Page 1 of 1
Author:  brombo [ July 18th, 2016, 2:55 pm ]
Post subject:  Free Homemade Amp
I make this when I though I was going to make a tri-amp system with horn mid-range and tweeters. It is two DTA-2 Class-T amplifier modules from Parts-Express with a packaged power supply. The DTA-2 modules are modified so you can set a pot and zero the DC offset. I though zero dc offset was needed if the amps were to directly drive horns. I hooked up and tested on of the modules into a dummy load and it worked fine. Pictures below -
Author:  mix4fix [ July 19th, 2016, 12:32 am ]
Post subject:  Re: Free Homemade Amp
I'll take it. Does it have a cover?
Author:  brombo [ July 19th, 2016, 7:55 am ]
No. Make your own cover.
Author:  mix4fix [ September 10th, 2022, 1:02 am ]
Passing this on to the next person. Free.
Author:  mix4fix [ November 7th, 2022, 10:21 pm ]
Free. Bringing it to CAF.
Author:  mix4fix [ November 10th, 2022, 10:43 pm ]
Available at CAF.
Author:  mix4fix [ January 21st, 2023, 5:38 pm ]
Amplifier has been passed along to someone else.
